Shocks for a 88 sprint
Seems like loads of confusing info out there, sites offer fronts not rears, obscure makes i've never heard of - rebuild this and that.
Can anybody clear up which new shocks (front and rear) are suitable for a late sprint, sporty adjustable or standard - and where to buy them.
Brussels
Brussels
Sprint 1.7QV 1989
Re: Shocks for a 88 sprint
I got mine - ages ago - on Italian eBay for a song. Do a search on Ammortizzatori Alfa 33 or Sprint or Sud or Arna.
Tried Italian still no luck, can I get the original ones rebuilt?
Sprint 1.7QV 1989
What make are your current shocks?
To be honest no idea, I believe they are the standard units. Is there an easy way to check?
Sprint 1.7QV 1989
They are probably spica on the front. If so you will need some koni inserts which are hard to get hold of. The rear shocks are still pretty easy to get.
The Spax gas shocks i fitted to the rear of mine are working very well.
Rears would be good for a 1984 Sud too?
I couldn't find any reasonably priced ones last time I looked....
05Alfa1662.0GrigioGeo-Daily
00Alfa1662.5Sporto-Verde Argo
i think GAZ do them for about £80 each but they can be rebuilt.
Used on the Rear of the rally car without any problems
I think I paid £100 each, or some where close to that.
Just emailed Gaz, hopefully they can do the front and rears. Will let you know what they say
Sprint 1.7QV 1989
Just had a look and my fronts are BOGE 549122, can you have these re-built?
Sprint 1.7QV 1989
Not having much luck, cannot find any equivalents for sale new or anyone who would re-build the Boges. Posted a wanted requested, if anyone has any ideas of where to get replacements please let me know.
Sprint 1.7QV 1989
If GAZ don't come back to you let me know and I will contact them. Does yours have the Sud or 33 running gear?
For the fronts I had to send them some old struts and they built the furniture onto one of their units.
Gaz said they did not make them. Mine is the later sprint compatible with the 33. It’s a 1988 1.7.
Sprint 1.7QV 1989
If yours is a late Sprint with outboard front discs, and rear drums.......its the same as the 83-89 Alfa 33.
So, try searching Alfa 33 Shock absorbers on ebay?
Done that. All manufacturers have discontinued. No fronts for sale.
Sprint 1.7QV 1989
Are you looking on ebay Belgium?
Maybe try ebay UK
or ebay.it
Maybe try ebay UK
or ebay.it
Do you want to keep it on standard springs or prepared to go coilover?brussels wrote:Gaz said they did not make them. Mine is the later sprint compatible with the 33. It’s a 1988 1.7.
They may not list them but I know they have helped me when I have phoned and spoke to them.
Sprint88qv
I got some second hand front koni inserts from John at JustSuds along with some already converted front struts to accept them. Then I had Shaun Pickering at S.P suspension refurb the front inserts. I then managed to get some brand new rear koni shocks from somewhere....i’ll have to have look back in my receipts to find out who (I’m on holiday at the moment)....I think it was the Alfashop (but it was a few years ago now). I also got a full set of polybushes from the too.
Your vehicle will be identical to mine Brussels, so I can give you part numbers when I get back from holiday.
Hope this helps.
Hope this helps.
Sprint88qv
Thanks Alfastrut, that certainly looks like them (I’ll check the numbers when I get back, but of course they may have released a newer version). If you have found them on eBay, that’s a star find as they were difficult to find some years back.
Brussels, if you’re not brave enough to chop up your own struts (I wasn’t
), just get an old pair from JustSuds and chop them up. You basically cut to top lip off, remove all the inners and drill a hole in the bottom for the bolt to retain the insert inside the strut.
The konis are for series 3 33, 1990 - 1994, but will fit if you use series 3 top mounts, the diameter of the top end of the damper rod is smaller than your Sprint, - and series 2 33 ones - and will be a very poor fit into the rubber mount. However, series 3 top mounts are the same 4 bolt pattern and should work fine. If you need Boge bodies and top mounts I have some ! Koni part no.s for your Sprint are 86- 2417 for Boge units, or 86-2303 for Spica - these also fit Suds with Spica legs.
John do you have rear shocks for a 1984 Sud?justsuds wrote:The konis are for series 3 33, 1990 - 1994, but will fit if you use series 3 top mounts, the diameter of the top end of the damper rod is smaller than your Sprint, - and series 2 33 ones - and will be a very poor fit into the rubber mount. However, series 3 top mounts are the same 4 bolt pattern and should work fine. If you need Boge bodies and top mounts I have some ! Koni part no.s for your Sprint are 86- 2417 for Boge units, or 86-2303 for Spica - these also fit Suds with Spica legs.
Thanks John for that it's always good to receive information that can keep us on the roadjustsuds wrote:The konis are for series 3 33, 1990 - 1994, but will fit if you use series 3 top mounts, the diameter of the top end of the damper rod is smaller than your Sprint, - and series 2 33 ones - and will be a very poor fit into the rubber mount. However, series 3 top mounts are the same 4 bolt pattern and should work fine. If you need Boge bodies and top mounts I have some ! Koni part no.s for your Sprint are 86- 2417 for Boge units, or 86-2303 for Spica - these also fit Suds with Spica legs.
Craig
I don't have any Sud rear shocks at the moment, - but Spax do Sud rear shocks, you can buy directly off them.
I have some Koni rear shocks, new (red) or used (yellow)..
