Sud Ti Race Car
fly33boxer
Sud Ti Race Car
Post by fly33boxer »
Hi Guys,
Well some of you here may know me but I have been around for a while but new to this forum. Seems that there are a lot more active topics relating to Suds/33's than the other forums...Great!!
I have been quiet on the forum side of things for the last 3 years but have not stopped work, which as we all know is next to near impossible =).
I originally started out sprinting my 33 16v but then later decided it was a tad too clean for racing. This brought on the search for an Alfa Sud as they were a bit lighter and have always been a family favourite.
The Sud came from a close mate and had been sitting in their front yard for two years, snapped it up for $150 =))))
The original state was not too bad, couple of dings, broken lights and of course the std single carb motor, but nothing some TLC could not fix.
Over the next 3 years the car was completely stripped and rebuilt with the help of a lot of other cars for donor parts. After this the modifications just kept going and going and going....
I could talk about all of the modifications but will try and keep it simple:
- 1983 Sud Ti
- Seam welded engine bay, half rollcage (still street registered)
- 16v strut bars
- 16v radiator
- 1.7 twin carb solid lifter ver (match ported, C&B Cams, Lighter internals, 16v oil pump, Crane ignition, tuned length extractors, custom valves & cuts)
- Koni yellows, Spherical top mounts, Super pro bushings, spherical adjustable track rod arms, adjustable panhard, custom springs, Camber adjust kit
- 16v suspension
- Outboard brake setup - Wilwood 4 piston calipers, bias valve, braided lines, PMU pads
- Lightweight Enkei racing wheels (4.4kg each) Toyo Semi slicks
And a whole lot of OCD detailing, polished parts, re-nickel plated bolts, SS bolts and lightweight trim parts to make it look a bit more presentable.
As it was for $150
As it was for $150
The work begins
The work begins
Whole lotta tar
Whole lotta tar
Yup was a decent amount of weight
Seam welding and finishing off
fly33boxer
Re: Sud Ti Race Car
Some more Photos
Painting
Painting
Sunroof option - new piece of metal with stepped edge, sealed in and 100 rivets - done!
Not too bad for a track car
Came up a treat
Came up a treat
Vitalonis
Vitalonis
fly33boxer
Re: Sud Ti Race Car
More
Freshly coated
Freshly coated
Blasted and machined to take newer GM thermostats - Lots of different temps available
Drilled out strut holes with custom offset camber slugs
Match ported inlet and exhaust
So clean
So clean
fly33boxer
Re: Sud Ti Race Car
More again
FMOC install - Trofeo inspired
The lengths I go to for perfection - Lathed SS allen key bolts all round
Custom rear stabilizer and more detailing
Adjustable panhard
Adjustable panhard
fly33boxer
Re: Sud Ti Race Car
More...
Sperical arms
Sperical arms
Wilwood's
Wilwood's
Cold nights building 1200 boxes
Half cage and rear panel work
fly33boxer
Re: Sud Ti Race Car
again..
Suede wheel and dash, custom gauge panel
Gas strut bonnet
Gas strut bonnet
Enkeis
Enkeis
Mates 33 1.7 twin carb and my Sud
fly33boxer
Re: Sud Ti Race Car
Couple of shots of my 1990 16v too
Re: Sud Ti Race Car
Welcome on board mate.
Super collection of boxers, which all look very , very smart.
Thanks for sharing your projects. 8-)
Re: Sud Ti Race Car
Welcome to the dark side ;)
Great looking boxers 8-)
Re: Sud Ti Race Car
Car looks really good
Be interested to know more about your rear anti-roll bar.
dralf1965
Re: Sud Ti Race Car
Post by dralf1965 »
Great cars, thanks for sharing.
Re: Sud Ti Race Car
great detailing on the sud, 33 looks great too.
funnily enough i too have a silver sud and red 33 16V....
welcome on board ;)
Re: Sud Ti Race Car
So are you now on the lookout for a nice S2 in white Kev ? :lol:
Re: Sud Ti Race Car
Real nice cars Fly.
Well done, huge credit to you :P
fly33boxer
Re: Sud Ti Race Car
rsfruitbat wrote:Car looks really good
The bar is a K-Mac kit but they seem to only be custom order now. I manufactured the brackets myself to mount to the rear axle and the rest was included in the kit. The brackets for the ends are thick L bracket steel which go through the rear suspension bolts.
Here is a sketch of a bar we had made for my 33 16v
fly33boxer
Re: Sud Ti Race Car
Re: Sud Ti Race Car
Any idea of a contact address and a price?
Did you find it made a big difference?
fly33boxer
Re: Sud Ti Race Car
rsfruitbat wrote:Any idea of a contact address and a price?
I got my stabilizer from Car Torque here is South Australia (08 8362 7667) and they sent my plans direct to Kmac
http://www.k-mac.com.au/
They should be able to help you out.
As for the difference, yes the car is considerably more stable through cornering. Some people have some very wired ways of running stabilzers in the suds....I just tend to have a small light one in the rear and a medium up front and its great.
Also have a medium on my 16v too
Re: Sud Ti Race Car
Thanks for that
