1.2ti Gearbox
1.2ti Gearbox
Post by Marlow Sud »
I am looking for a good 1.2ti gearbox. Please get in contact if you have one. thank you.
Re: 1.2ti Gearbox
Marlow Sud wrote:I am looking for a good 1.2ti gearbox. Please get in contact if you have one. thank you.
Hi Simon, my friend may have one, I'll ask him and let you know,
Richard.
Re: 1.2ti Gearbox
I may decide to sell mine too.
It was rebuilt by BLS prior to install in the track car, and it has covered way less than 100 miles!
2 boxer meet track days at cadwell park that both came to premature ends! Ooops! :)
I do have to suss out whether the lsd installed will swap out with my replacement gearbox first, but if thats the case, she'll be coming out and up for grabs.
Re: 1.2ti Gearbox
Thanks for the replies. Richard and Shrew. I think my existing box may have a Quaife LSD in it as I have a bill in the file for the LSD being re-furbished so removal of an existing LSD may not be a problem?
I understand that sud gearboxes are generally considered a weak point (especially 2nd gear synchromesh) but are there things that can be done for them to last longer? Several things spring to mind:
1. Driving technique. Could I have made a major contribution to the demise of 2nd and 4th gears in my gearbox?
2. Oil. Is there a particular oil or additive your recommend?
3. Oil temp. Is a gearbox oil cooler recommended?
4. Inboard brakes. Surely there must be a great deal of heat transferred to the gearbox with inboard brakes?
Any comments gratefully received. I would definately be interested in your gearbox Shrew on the basis that it is a known quantity.
Re: 1.2ti Gearbox
I think the 2nd gear synchro is a combination of non too strong components, and the lively engines resulting in many a driver participating in the traffic light grand prix.
So, regular oil changes and sympathetic driving is just about all you can do i believe Simon.
My 33 16v had a terrible 2nd and none too clever 3rd, by 40k miles, yet I've had other cars, including my last sprint, well over 100k miles, still all original, gearbox untouched.
No rhyme or reason, theyre just not very good i fear! :(
Re: 1.2ti Gearbox
Thanks for the feedback and advice Shrew. I will look forward to opening the gearbox up and having a look at the components to see what has worn.
Re: 1.2ti Gearbox
No worries,
I hope you dont mind too much horror! :o
Very tired synchros and baulk rings are normally quite obvious, with sharp, lifted, uneven points to the teeth, and tarnishing sometimes i suspect when the hardenings long since faded away!
If you find yourself interested in my gearbox, let me know and I'll try to suss my replacement box out sooner rather than later mate :P
Re: 1.2ti Gearbox
Hi Shrew,
I am definately interested in your gearbox.
I am not in a rush so can take it when you are ready. Just let me know. I will follow up from time to time.
In the mean time I will remove the other gearbox and take a peek inside. I will need to sort out whether it has the Quaife LSD.
Re: 1.2ti Gearbox
Whilst you're there, check whether the diff is 8 or 10 bolt.
Speak soon
Shrew
Re: 1.2ti Gearbox
Will do.
One is a 1.2ti gearbox version and the other a 105 gearbox version?
88liam
Re: 1.2ti Gearbox
Post by 88liam »
Hi Marlow,
Pretty sure you can determine whether or not your gearbox has a lsd or not
by selecting a gear and turning either input shaft (left or right) in
a clockwise direction if the other input shaft turns in a anti clockwise
direction there's no lsd in a clockwise there is,
Liam
Re: 1.2ti Gearbox
Sud gearboxes used a 10 bolt crown wheel, 33's and later Sprints used a 8 bolt crown wheel, - are you looking specifically for a 1.2 ti gearbox, or any gearbox with a 4.11 final drive ?
Re: 1.2ti Gearbox
Hi Liam,
Thanks for the tip for verifying whether an LSD is fitted.
Hi John,
Good point.
I am advised that the 1.2ti five speed box has the best gear ratios for high revving race engines and that the later 1.5ti 5th gear is effectively an overdrive?
Best Regards,
Re: 1.2ti Gearbox
Now up for grabs simon in the classifieds if you want it?
competition is fierce already! :shock:
