Guys does anyone have top mounts for a 1978 Alfasud Super 1.2 ?
Got a mate who over tightened them and snapped a bolt.
These are the ones I need:
Top mounts for Alfasud 1.2
- AlfaCorseChris
- Attachments
- 2014-05-21 05.51.35.jpg (10.73 KiB) Viewed 8696 times
- 2014-05-21 05.51.36.jpg (8.43 KiB) Viewed 8696 times
Re: Top mounts for Alfasud 1.2
just take the strut out, knock out the broken stud, weld a new one into place, fit strut back to car....job done
- AlfaCorseChris
I was under the impression that the top mount's casting is not easily weldable...
If you've done it before mate, then I'll just do that
Supercharged16v wrote:I was under the impression that the top mount's casting is not easily weldable...
the part where the studs go is steel, but galvanised i seem to remember. you need to grind the galv off first then it will weld just fine
- AlfaCorseChris
Right on mate, I'll give it a shot
