Physics Question.
Physics Question.
On a bicycle with twenty eight spoked wheels is the weight of the rider supported by the spokes above or below the hub? Can't wait for Lauren's explanation.
Re: Physics Question.
I would guess at both. Ones above are in tension. Ones below are in compression. Spokes being angled helps spread the load under acceleration and breaking?
The spokes that you are hanging on as you progress down the road are the top spokes in relation to the rim,
but the side spokes in relation to the hub. That is normal for a 3 spokes crossing wheel.
So the top spokes on the hub are side spokes on the rim, and so on around the wheel.
The tightest spokes are always moving backwards as the wheel moves forward. Which I love as a mental image.
So what about a radial spoked wheel?
Then your just hanging from the top. Which is why you see touring bikes with 3x crossing to give a kinder life to the body on the bike, rather than a stiffer wheel to go faster.
There is of course periodic stresses as load changes and torque altering things and when you look into it things get very complex quite fast I find.
Also you may find it interesting from an engineering point of view to look up Berd spokes which make some of the string
spokes which people are starting to use. Hooking a bit of string around a hook on a flange, then building it in to a wheel to
go down the road is a bit mind bending to me.
What everyone above said
I think I would rather have a bike like this one though...
https://luxurylaunches.com/wp-content/u ... 0x845.jpeg
Spoked wheels just seem so passe these days
