33 rev counter feed
Posted: Sat Apr 19, 2014 10:01 am
by Veesix75
I fitted an 8v on carbs to a 33 ie and used the standard clocks / rev counter etc which worked fine.
Would the same work with a 16v rev counter, or is the 16v rev counter fed from the ecu?
Re: 33 rev counter feed
Posted: Sat Apr 19, 2014 10:19 am
by Simonsud
Not sure on a 16v boxer but most coil pack engines work on wasted spark so send out a different signal to a signal coil set up so rev counter will read wrong but you can get a convertor box I've got one on my van to make a petrol rev counter work off a alternator signal I got it from America for about £50 delivered think its made my Dakota digital
Posted: Sat Apr 19, 2014 9:10 pm
ooh, i should know this one.
i put a 16V engine in a sud recently with sud clocks, seem to remember using a coil feed? i'll have a look back and see ;)
Posted: Sun Apr 20, 2014 10:33 am
by Veesix75
Thanks all, let me know if you do dig out the answer Kev.
Posted: Mon Apr 21, 2014 10:07 am
Feel free to come and ponder over such muses at mine Tim,
Ill be pulling the 16v sud track car apart eventually anyway, so a little investigative removing isnt a problem! ;)
Posted: Mon Apr 21, 2014 6:15 pm
just got chance to look back over the sud 16V track day car, there should be a thin black/white lead on the neg side of the coil. this should feed a rev-counter
hope that helps in some way ;)
Posted: Mon Apr 21, 2014 7:59 pm
by Veesix75
Thanks both - I might take you up on the offer shrew..cheers.
Posted: Mon Apr 21, 2014 8:58 pm
no problem Tim,
any time at all mate, you know where i am yeah?
Posted: Thu Apr 24, 2014 9:39 am
by Veesix75
I've lost the address Shrew, but will call you in the next week or so to catch up.
Posted: Thu Apr 24, 2014 6:56 pm
no worries Tim
pm sent for when you're ready, and i should be at the workshop virtually all of next week anwyay.
cheers
