33 rev counter feed
33 rev counter feed
I fitted an 8v on carbs to a 33 ie and used the standard clocks / rev counter etc which worked fine.
Would the same work with a 16v rev counter, or is the 16v rev counter fed from the ecu?
Simonsud
Re: 33 rev counter feed
Post by Simonsud »
Not sure on a 16v boxer but most coil pack engines work on wasted spark so send out a different signal to a signal coil set up so rev counter will read wrong but you can get a convertor box I've got one on my van to make a petrol rev counter work off a alternator signal I got it from America for about £50 delivered think its made my Dakota digital
ooh, i should know this one.
i put a 16V engine in a sud recently with sud clocks, seem to remember using a coil feed? i'll have a look back and see ;)
Thanks all, let me know if you do dig out the answer Kev.
Feel free to come and ponder over such muses at mine Tim,
Ill be pulling the 16v sud track car apart eventually anyway, so a little investigative removing isnt a problem! ;)
just got chance to look back over the sud 16V track day car, there should be a thin black/white lead on the neg side of the coil. this should feed a rev-counter
hope that helps in some way ;)
Thanks both - I might take you up on the offer shrew..cheers.
no problem Tim,
any time at all mate, you know where i am yeah?
I've lost the address Shrew, but will call you in the next week or so to catch up.
no worries Tim
pm sent for when you're ready, and i should be at the workshop virtually all of next week anwyay.
cheers
