Ti Trim
Ti Trim
Wanted ! Help. I need a RH front door lower window trim for a Sud TI. It’s The one that runs along the top edge of the door skin at the bottom of the window With The seal In it .
Alfastrut
Re: Ti Trim
Post by Alfastrut »
I've one lou
Re: Ti Trim
Cheers Craig. Put it with the rear axle and I’ll try to get over to see you in a few weeks .
Alfastrut
Re: Ti Trim
Post by Alfastrut »
Will do Lou. Is there anything else you are after?
Re: Ti Trim
Hi Craig. Actually I’m also short of the plastic moulding on the bottom of the door that the door panel sits into . If you’ve got one.
Alfastrut
Re: Ti Trim
Post by Alfastrut »
I'm pretty sure I've got one of those. Anything else?
Re: Ti Trim
No I think that’s it thanks Craig. If I do find anything else I’m short of I’ll ask
