Rear bleed nipple size?
Anybody know the size of these? There's some fiat ones on fleabay that are 8mm by 1.25 are these correct and would they have the correct angle to seat properly? And any good tips to get it out ? It's well seized and rounded off .I've been bleeding it through the in pipe union ! Off the axle facing down of course so it's at the highest point .
Re: Rear bleed nipple size?
I'll send you one Stephen, I have quite a few old calipers here that will have a good bleed nipple somewhere amongst them !
Cheers, I've bought some plumbers freezing spray , going heat, freeze heat, freeze and then no doubt snap it off !
