there are 3 gearboxes here, all in unknown condition.
they are obviously not sud ones, or early sprint for that matter, no studs for inboard calipers.
from fitting a clutch plate and counting rotations i've worked out which ones they are from, gear ratios etc. reverse gear is the same ratio on all 'boxes so working which diff is in was easy without having to take the sump pan off and count teeth.
for ease of identification the 3 will be known as mount (the one with the mount on
the diff ratio in the "mount" gearbox is a 3.7. i calculated all the 5 gear ratios and they correspond to the S2 33 & sprint 1.7. seeing as it has a speedo drive in place for a cable not an electric sender we can assume it's a sprint 1.7 QV gearbox.
the non mount 'box has a diff ratio of 3.88 again the 5 gear ratios were checked and they compare to a S2 33 1.5 ti. they also fit the same ratio to all 5 gears & diff as the S3 33 1.5, 1.7 & 16V. there is no drive in the speedo hole on this one.
the last is clearly a 4X4 'box but i didn't realise until now there are different ratios in those, i will check tomorrow.
there may well be different models that these 'boxes fit, please check the great list from alfa pages to see.
http://www.alfa-pages.co.uk/gearbox.php
these 'boxes are as i say in unknown condition although they do all select gears and have oil in, rotate smoothly etc. i can't vouch for any more than that, even taking the sump pan off and having a look doesn't guarantee things.
so with that in mind i'm open to sensible offers, not big offers at all as being unknown they have limited value. they are of no use to me so grab a bargian and save me some storage space!
