Single choke solex tuning?
sudboy1490
Post by sudboy1490 »
Hi guys does anyone have any experience with the solex single choke carb? I have a 1.3 super that seems to be running lean, it’s got a new carb fitted and is fine when you put your foot down. However low to mid throttle it feels like it’s holding back as thought the idle jet is too small. Iv wound out the idle screw as far as I dare, to a point where it’s running it’s best at tick over, the same with what I presume is the air screw. Iv tried it with the screws wound in more and it seems worse.
I’m wondering if this new carb may be jetted differently to the original?
Col
Re: Single choke solex tuning?
Have you still got the original carb?
Maybe fit the jets from it.
Is the vacuum advance operating ok?
sudboy1490
No irony have the original carb, I wish I did so I could check the jet sizes
Hi Col - according to my Haynes manual, the Solex C32 DISA 21 single-choke has the following jet sizes:
Main jet = 127.5
Main air metering jet = 150
Idle jet = 65
Idling air metering jet = 80
Choke jet = 55
Accelerator pump jet = 45
That was used on the early 1200. Later models used the C32 DIS40 and DIS41, C32 EIES 43, 44 and 45. Jets in the following order:
Main
Main air correction
Idle
Idle air correction
Econostat
Accelerator jet
Accelerator bypass jet
C32 DIS 40 = 137.5, 165, 62, 90 or 80, 80, 45, 50
C32 DIS 41 = 135, 165, 62.5, 80, 60, 50, 50
C32 EIES 43 = 122.5/137.5, 190/180, 55, 135/120, 45/10, 55, 0
C32 EIES 44 = 120/137.6, 170/180, 55, 135/120, 0/100, 55, 35
C32 EIES 45 = 120/135, 170/190, 55, 135/120, 0.85, 55, 35
Depending on the model there seems to be quite a lot of variation.
sudboy1490
Thank you Lauren I’ll have to take a trip to Ferdi I think
sudboy1490
It turns out the carb is the original one that’s been refurbished. I opened up the idle and main jet by .05 and it’s purring like a kitten
Job done
Sprint88qv
Post by Sprint88qv »
Nice one. Very satisfying that sort of job :-)
Good result Col, you know we now need a photo of the car. :D
sudboy1490
Hi Keith it’s a lovely original car just coming up to 20,000 on the clock
sudboy1490 wrote:It turns out the carb is the original one that’s been refurbished. I opened up the idle and main jet by .05 and it’s purring like a kitten
Job done
That's great news - that's another little cracker of a car you've got there 8-)
Where do you keep finding these gems ?
Lovely find and such low mileage.
Magic.!!
Is that a red car in Redcar?
NEG
Post by NEG »
Great looking car!
sudboy1490
It certainly is Dave
