Anyone know where to get new ones of these from?
or can you get polishes to do the job these days?
side engine mounting rubbers
Re: side engine mounting rubbers
https://alfa-restoration.co.uk/shop/pro ... cts_id=154
or if you just need the rubber bush that goes through the metal bracket on the chassis leg, the part number is 60501317 which should still be available from your friendly local main stealer
They were not fitted to earlier cars ( as you may know ) and I am note sure when they started fitting them, I presume it was with the 1.5 engine. I fitted a 1.5 engine from an ARNA many years ago to my series one Sud without fitting the stabiliser bar and I have never had any problems.
1976 1.5Ti
1977 1.2Ti
1989 1.7 Sprint Veloce
1989 75TS
2003 147 2.0TS Lusso
2004 MX5 1.8S
2002 1.6 Focus LX
1977 1.2Ti
1989 75TS
2004 MX5 1.8S
2002 1.6 Focus LX
dave.armstrong
I used Mercedes Sprinter anti roll bar bushes on mine that I got from Ebay.
Yes Merc Sprinter bushes on mine too
Me three . Not fitted yet but I have to make a mount on the chassis leg as my car was never fitted with one with the 1186 motor.
Planned on fitting the one the 1490 came with when that goes in. Is it to reduce torque flex ?
Thanks guys
Any particular Mercedes sprinter??
Yep, to control the engine twisting on the centre mount.
I need new rubbers also, managed to find a new top engine mount a while ago, we also sleeved a worn one with some u shaped metal pieces, aboutb4mm thick each. The worn top mount will mean lots of engine movement.
Ebay item
312584123619
312584123619
