AlfaSud Parts Available
its_welshy
Post by its_welshy »
Hi All,
I know someone selling the following parts.
The guy selling them knows pretty much what everything is worth, and won't sell for ridiculous money (so don't offer a fiver for a windscreen :lol: :lol: )
I've put this up here as I've bought what I need and wanted to help anyone else out that needs it.
Let me know if you need anything
Justin
ALFASUD SPARE PARTS (SOME NEW, SOME FROM A 1981 ALFASUD Ti 1.5)
EXTERIOR ITEMS
2 x headlights – brand new (outside lights for twin headlight models)
2 x twin headlamps with plastic surrounds, bulbs and rubber backing covers
1 x main beam headlight – brand new
1 x rear right light cluster – brake light and indicator, with rubber surround
1 x rear left light cluster – brake light (broken) and indicator, with rubber surround
2 x rear reverse and fog light clusters (one for each side of number plate)
1 x windscreen
2 x rear passenger windows – including opening attachments
1 x front grille with silver Alfa heart and badge (needs touching up and a new badge)
1 x front right central fascia for black plastic bumper
4 x black and white Alfa wheel centres for alloys
4 x plastic wheel centres for non-alloy wheels (wheel nuts go through them)
2 x silver cloverleaf plastic trims – partly worn (run from above rear window to boot aperture)
2 x rear window grille trim – sit behind the rear windows
1 x front right bumper mounted indicator (housing fine, lens cracked)
1 x front left bumper mounted indicator (housing fine, lens cracked)
2 x front indicators – wing mounted
1 x passenger side door mirror
MECHANICAL ITEMS
1 x clutch mechanism – brand new Alfa original
1 x clutch plate – brand new Alfa original
1 x set of 4 gaskets – brand new Alfa originals
1 x gasket – brand new Alfa originals
2 x gaskets – brand new Alfa originals (carburettor)
1 x alternator
1 x release bearing – brand new Alfa original
2 x sets of rear brake pads – brand new Alfa originals
1 x Bosch coil
1 x distributor (with cap)
1 x brake caliper (for refurbishment)
1 x fan unit (housed in the bonnet) with electrics and switches for dashboard
SUNDRY ITEMS - MECHANICAL
1 x indicator and light stalk with wires – push end main beam (needs refurbishment)
1 x indicator and light unit with wires – push end main beam
1 x windscreen wiper unit
1 x windscreen wash bag with motor and tube
1 x windscreen wiper washer tubes and link unit
1 x radiator water reservoir and pipe attachment
2 x hydraulic boot struts
1 x air filter housing (needs tidying up)
1 x airflow housing with outlets to wheel arches (sits at top of bonnet)
1 x fuse box with wires out and the frame it sits on (plus fuses)
1 x bonnet release mechanism, with cables
1 x boot release mechanism
4 x rubber light backs – where wires enter back of lights
1 x light centre – wire that holds the bulb in place
1 x screw for holding spare wheel in place
2 x vent intakes
1 x wheel brace / wheel nut remover pack - in bag
Numerous wire sections with plastic plug-in attachments
SUNDRY ITEMS - INTERIOR
1 x 3 spoke plastic and metal steering wheel (needs tidying up)
2 x interior door panels – including armrests
2 x metal strips for door sills – where carpet meets door sill
2 x plastic strips for door sills – where carpet meets door sill
2 x plastic seatbelt housings
2 x seat belts
3 x roof-mounted hand holds
2 x plastic trims for windscreen pillars
1 x plastic trim for boot catch housing – includes the electrical connection points
1 x handbrake grip
1 x handbrake housing
1 x accelerator pedal
1 x interior roof light – includes plastic surround, light unit and bulb
1 x rear view mirror
Selection of black plastic screw covers
3 x plastic caps for rear boot ledges (above wheel)
1 x fan housing fascia with cigarette lighter
1 x central vent unit (top of dashboard)
1 x driver’s side vent
1 x steering wheel column housing
1 x dashboard housing for speedo, rev counter, warning lights
1 x speedo and rev counter and warning lights
2 x front seat belt clips
1 x centre console unit with ashtray and tray (sits behind handbrake)
2 x cream sun visors – one with mirror and one with a pocket (need a clean)
1 x centre gearstick console with gear stick cover, oil and heat gauges and ashtray
2 x rubber rear parcel shelf lifting straps
2 x doors to access wheel brace kits (in boot panels)
2 x trim panels for roof (from rear window to boot ledge)
2 x trim panels for sides of boot
1 x trim panel for side of boot below the boot catch
1 x boot courtesy light
Re: AlfaSud Parts Available
Hi Welshy. Can you PM me a price on the passenger mirror and a bulb holder. Cheers Tony
its_welshy
Sud 145 wrote:Hi Welshy. Can you PM me a price on the passenger mirror and a bulb holder. Cheers Tony
No worries, I'm going to email him friday as I want a few bits, thought I'd get a list and ask for prices on bulk :)
Hello mate
The outer headlamps and surrounds are of interest to me if you could find out please
buzzed
Post by buzzed »
I'd take these:
1 x Bosch coil
AlfaCorseChris
Post by AlfaCorseChris »
Noooooooooooooooooooo not the Bosch !!! :o
Anywayz, I'd be looking for a ingition switch for my S3 Sprint if there's one available ... I think they are exactly the same as the SUD's
buzzed
Post by buzzed »
Cancel my dizzy request. I got the little sucker running ;-).
AlfaCorseChris
hahahaha :)
its_welshy
I'm still waiting for the old boy to email back!
He acknowledged my email and said he's send me a pice for all the bits.
U619825
Post by U619825 »
Hi there, I`m interested in the wheel centres for alloy wheels and I`m also looking for 16 wheel bolts suitable for the "finned" alloy wheels ?
Regards..
amichie
Post by amichie »
Are these parts still available?
its_welshy
I've just collected all these parts and paid for them as a job lot.
Let me know if you guys need anything that you can't find.
