Hi all
Does anyone have any series 3 suspension struts for my J plate 33?
Preferably an aftermarket upgrade version such as the koni or avo etc.
Not full race, they are for a road car.
Thanks in advance
Shrew
Alfa 33 struts, konis avo leda etc???
Re: Alfa 33 struts, konis avo leda etc???
Have you got springs and pans ?
Hi Lou
yes, everything is as stock at the moment, so i've ordered a full set of (Spax SSX) springs to suit the stock dampers.
whilst everything appears good with the dampers currently, the SSX springs are a 30mm drop and progressively wound with around 25% extra stiffness, so i would rather have a performance damper to suit, that copes with the shorter and lower travel.
what you got
what you got
I may have a spare pair of Koni inserts which struts you got Boge or Spica ?
