I could do with a couple of good strut top mounts , and additionally some of the spacers/inserts that push inside the rubber and the strut fits inside. I've got some top mounts missing the insert.
Strut top mount and bearing
Re: Strut top mount and bearing
I may be able to help. let me look through my various piles of bits. Btw what car are these for ?
Got my last standard top mounts from justsuds a few months ago.
Thanks, it's for a sud but with 33 suspension so 4 bolt tops. I've got Koni's with the 'thinner' insert as per a early 16v and the thicker ones as per the earlier 33's
castleated rubbers or the smooth ones are fine.
I'm sure I'll have some of these Tim, just confirm what size the bore of the rubber needs to be to take your shock.
