I'm after a 33 16v Crossmember and Carb conversion adapter plates please - Long shot but worth a try.
Thanks all.
Alfasud Sprint 16v Conversion Parts
- AlfaCorseChris
Re: Alfasud Sprint 16v Conversion Parts
We had a custom order with 4 other guys on those carb adaptors last time mate.
They are quite expensive
Crossmember, maybe Shrew can help you out ?
Hi Chris, thanks for the reply.
I was hoping that maybe someone who was on the carb adapter group buy had changed their minds.
Otherwise, I'll be buying a new set from Di Michele in Germany too.
I've also had a good chat with Shrew about all of my conversion options.
Thanks again.
Thanks again.
- AlfaCorseChris
I think you'd be better off buying the ones from Italy which are more expensive.
The plates you need to make, drilling out the water temp switch etc, will cost you more in the long run
