Rust removal by Electrolysis
Posted: Mon May 02, 2016 9:19 pm
Seen this method done on-line, sure we have members on here that have done the same thing too?
Never got around to trying it myself.
So with plenty of candidates now for painless rust removal of delicate parts from the Imp and integrale and a Bank Holiday Monday free from major commitments I thought I'd have a go myself.
First task was to gather all the components...some variations on what the 'net describes to use but I couldn't see why it wouldn't work...
Instead of thick bars I found some old angle sections that I screwed to the inside of a plastic bucket, a non-metal container is vital as will become clear later...
You may have noticed that the metal bars leading down into the bucket are all attached to each other, I used heavy duty battery type cables but not sure if they needed to be so heavy duty.
The bucket is then filled with plain water but the advice is to use washing soda crystals, washing powder seemed about the same to Rob and me so a scoop of Daz was stirred into the mix.
The piece you want to remove the rust from then needs to be hung into the mixture but not touch the metal bars that are screwed to the sides.
You then attach the positive lead from your battery charger to the metal brackets and the negative to the piece via a metal hanger all suspended in the solution without touching the other metal parts, a plastic or wooden cross-bar is perfect
First thing we tried was a bracket of some sort off the Imp, quite rusted but could have been cleaned with a wire wheel or brush.
Difficult to see but once the process starts you see the bubbles rising from the work piece, best to do it in a ventilated place as the bubbles are apparently Hydrogen?
After about half an hour we couldn't wait any longer to see if it was doing anything....on first pulling the piece out we were really disappointed to see it looked not that much better than when it went in, until I remembered you had to wash the remnants off. A quick rinse with a wire brush and the results were great to see.
Would it work on this bracket?
Lovely job
Lovely job
