Shopping list
Shopping list
Hi guys
I hope your all safe and well in these sad times .
As I'm now not working . The 33 will be looked at . So there's a couple of bits I need .
What fuel hose do you peeps use as im going to fit a swirl pot . I'll be running it inside the car . As will the brake lines be . Which brings me onto the brake side. I need a length of braided brake line with stock fittings . This will go from the back axle beam to the inside of the car .so needs to flex obviously.
Any ideas where to buy would be great guys
Stay safe
Jb
Re: Shopping list
I tended to trust a good car part place near me and they would if you chose a quiet time go off and root around for something that would do the job.
Also just bought their best modern fuel pipe then cleaned all the writing off it so it looked more period. Good luck.
Re: Shopping list
Yeah I may give a couple the local a call tomorrow cheers
Re: Shopping list
There not that many places to order from online, I think demon tweeks bought jjc.
My fuel line is external still, copper front to back and rubber fuel hose each end, I think it’s 8mm.
I use a facet ‘barrel’ shaped pump.
Brake lines are inside.
Tweeks can be a rip off but the usually have everything you need.
Re: Shopping list
Cheers for that . Yes 8mm . It's just getting harder to order stuff now . Will keep looking . But on the ales now :D joys of having a mate who owns a brewery and delivers :D
Re: Shopping list
Hi Johnny
I use Pirtek for fuel hose and connections.
Alternatively try rally design. They will make-up braided brake pipes. Sensible money aswell.
Re: Shopping list
Hi adie
Thanks for that . Rally design is quite close to me . I'll give them a call tomorrow.had a look on their site yesterday. See if they can make up five .thye all the calipers will be sorted aswell then cheers
