Help fixing odometer
brussels
Post by brussels »
Hi,
My speedo works but not my odometer, i figured its probably a crappy plastic cog so took it all apart to have a look
All looked ok, no noticeable wear, nothing broken or missing - any ideas?
Next up the needles on both dials, both have gone a bit wonky! any suggestions on how to straighten them? its a softish plastic, quite pliable.
Finally, does anyone know what type the main lighting bulbs are?
Thanks in advance,
Brussels
Sprint 1.7QV 1989
Re: Help fixing odometer
The dials should be purely mechanical so something may be broken or missing, only other thing I can think of is is the reset button/mechanism stuck in? That would probably stop things moving.
On the needle front you could try warming it up then clamping it in between two straight pieces and cooling it down, maybe it will then hold its shape?
brussels
Post by brussels »
It could well be the reset button, is it a push or twist to reset? i've never tried it, guess this can be done without being connected.
Sprint 1.7QV 1989
brussels
Post by brussels »
Damn! Snapped one of the needles!!!
Can these be bought anywhere?
Sprint 1.7QV 1989
StescoG66
Post by StescoG66 »
I have a full instrument binnacle which may be of use - in case of emergency
brussels
Post by brussels »
Sounds good, can you pm me what you would accept for it?
Sprint 1.7QV 1989
