And the side skirts are off...
Re: And the side skirts are off...
Kev,
Dont think you would look back fella,
No such thing as luck, hard work,
which you are clearly not scared off,
Good Luck.
Liam
Good Luck.
Liam
stranger things have happened
cheers for the votes of confidence guys, not beyond the realms of possibility...
Great job as always Kev, Can't wait to see the parts and start putting it all together.
As you know I agree with the other guys, and would be happy to help fit out the "spray booth" as we planned out last week, the place is made for it.
Be a big step but you would have more free time (to get that Delta finished) and see more of the misses, she might wonder who you are mind
Alfa Romeo 33 (907)
Alfa Romeo Giulietta (940)
Should get them all polished up tomorrow mate, I'll drop as much in to you Saturday morning as I can, tell Lou to make some space in the garage. Don't want a 'bike dropping on them
Few hours spent on the car this afternoon. Plan was to get all the waxoyling done. Having borrowed an air gun from Kev.
First was to unload the boxes of parts that have been in storage for the last few months. All this and more has to fit into this. .
So a quick clean inside tracer to get rid of all dust etc gained from the spraying and the car backed out onto my dad's drive was time to get the compresser out. So got started with the waxoyl, passengers side cill and cross members done then on to the door internals again passenger's side all done then on to the driver's side. No air.... Compressor packed up. Spent the next hour trying to get it going but to no avail.
So ditched the waxoyling for now and concentrated on the shut lines.
Front doors needed to be lifted to align with the rears properly which meant the front wings had to come off to get at the hinges, then to refit the wings using stainless bolts, a couple of attempts each side to get the door lines okay then to line the bonnet to the wings. Bit of time with the bonnet hinges and the bonnet catch and all looked good. Than scuttle cover fitted with washer pipes etc, then fitted the washer bottle under the wing. Surprising where the time goes when you are trying to get the shut lines sorted but still will need fine tuning once the door latches are back on. So with 6 hours in I felt I had achieved so little but time to put it away until next week.
Alfa Romeo 33 (907)
I've a little 50litre compressor at home mate if you want to borrow it, it'll run the waxoyl gun no problem
car looking better with some contrasting black bits on though
Yep it absorbs time, but think of the many hours it will annoy you for if you have not lined it all up well.
Looking good. Keep going.
about my last update post on the thread
spent the day flatting & polishing all the parts I'd painted last Saturday, all 21 pieces! well, apart from one door mirror base that had some reaction so I sanded that back and painted it again, thankfully this time it's gone on smooth
same old same old pics, most bits now ready for fitting.
one last pic though, i'm useless at tidying up as Paul rightly points out. should really have packed away the Mrs spare kettle I borrowed to flat the primer down.......whoops
So had some time today to progress with the rebuild.
Got the rest of the waxoyling done having borrowed a Compressor from Kev, thanks mate.
Had another look at the shut lines and decided to move the offside wing back another millimetre or two just to even the sides up, happy now but still need to check the nearside rear once the catches are fitted.
Roof lining next, which was a little saggy for a start. Got it all up in place with a bit of a struggle but got there, all the roof accessories fitted. Then with only a little time left before I had to get home, Mrs had booked the Tesco delivery for 4pm, joy, so quickly fitted the rear bumper and lights, got the bumper off the garage floor so feel happier that it has less chance of any damage.
So shopping away and then got the grill reassembled which I think looks great now, but will probably be one of the last things to go on the car, but hey with a couple of minutes spare I couldn't resist.
Alfa Romeo 33 (907)
In the words of the said TESCO, every little helps.
Your car is looking very nice. top job .
Coming together very well!
bumper black bit has come up good mate, as has the grille
looking better each visit
A couple of hours spare this afternoon, so had a look at the front bumper to add in the black section in the slots which are in front of the radiator as per original spec. Clearly all was painted red by Kev knowing I was going to add the satin black later which meant that the paint was adhered to the plastic.
So was just a matter of making the area off. scotching it back for the rattle can satin black to adhere. Then fully masked out the red that needs to stay red. Then on with the black. A few coats later and masking off and happy with the result.
Alfa Romeo 33 (907)
Yes I use autoglym vinal and plastic care, but I apply it once to clear all the crap off and thoroughly rub it, I then apply a second coat and buff it up, which will usually dry dull, then I add a third and a forth coat very wet and just smear it across the surface and then let it dry naturally which dries with a sheen, leave for a hour or so then lightly buff. Looks really good but I know will wear off after a while I guess.KevJTD wrote:bumper black bit has come up good mate,
Alfa Romeo 33 (907)
So a bit more done today.
New disc's, brake calipers back on and bled.
A few other bits done like the gutter rails refitted, bit of a pain putting the rubbers back in as they fitted like an awning on a caravan so had to be threaded from front to back very trying!
Mirrors back on after they got their cables all connected and body's rebuilt last week.
Got issues with the central locking at the moment too. All working when I took it to bits but now refuses to operate. All the doors lock independently but not with the key as you would expect, all that happens is the key door locks and the relay makes a long buzzing sound. So new relay ordered hoping that it solves the problem. Could be an earth though but didn't have time to check.
Alfa Romeo 33 (907)
Don't you just love shiny bits
Looking good.
Looking good.
You are doing a great job.
So a couple or so of days off over the last three weeks has meant I have been able to make good progress. Putting it all back together with the parts I had spent fixing painting cleaning and labeling over the winter months. So pics of the last three weeks eventually getting to today's pics.
Then on to today. Got the last door cards in, inner wing covers fitted, changed to the original wheels and then the finally the side skirts are back on....
So then it was lights front bumper, fog lights and side repeaters. And finally getting the central locking working. Then on to today. Got the last door cards in, inner wing covers fitted, changed to the original wheels and then the finally the side skirts are back on....
Alfa Romeo 33 (907)
So here are the pics of the 33 basically finished
Paul
Just got to get the MOT done, hopefully next week and then hit the road for a few shake downs before Italy. Paul
Alfa Romeo 33 (907)
Paul
Alfa Romeo 33 (907)
looks great mate, really good now all built up
sure the MoT will be a doddle
Paul and Kev you have done a beautiful job on this car.
A real credit to you both, looks superb.
Superb!
That looks great, well done guys!
petrolhead wrote:and now would look a great time to reflect on its humble beginnings too,
its come a long way Paul since i unearthed your car from a lengthy garage sleep!
refer back to here to see how the car has been transformed, these shots are flattering in some ways! the lacquer peel in many panels, rot in a couple of door bottoms, along with the usual faded red (pink) paintwork that meant constantly having to polish it up before going out in it and the transformation is all the more impressive
glad to have been a help
and that paul had the vision to see what it could be
Good to see the contrasting pictures on the same page.
MOT booked for next Wednesday so fingers crossed for it.
And a big thanks to Kev for all his help and generosity with the car in may more ways than one, as without his help it would still be a vision.
I have to say I am very happy with the results and can't wait to get driving it.
Alfa Romeo 33 (907)
The very best of luck with the trip mate,
I think she'll do you proud!
Lovely to see it looking so good. ell done chaps.
Another cracking 33 is about hit the road . Well done chaps looks stunning.
it should breeze the MoT on Wednesday so expect to see it up at the unit .....
