Racing Saloon
Re: Racing Saloon
fascinating thread 8-)
Re: Racing Saloon
Post by Marlow Sud »
Hi Guys,
Bit of research on adjustable blow-off valves.
This supercharged car has two. It was made here:
Here is the car. Originally 1500cc supercharged, it is now 2.7litre supercharged running on methanol and capable of 140mph.
Here are the adjustable blow-off valves set to 8psi. This is the intake manifold one.
This one is next to the supercharger outlet.
Re: Racing Saloon
What a great place Simon. 8-)
Re: Racing Saloon
Hi Keith,
Its Brooklands Museum. I was over there this afternoon.
Lots of lovely cars and motorbikes and aircraft.
Re: Racing Saloon
Hi Guys,
My new supercharger pulley arrived today. Beautifully made. The new one is quite a bit smaller than the old one as you can see. Old belt and new belts fit the new pulley perfectly. Just got to get it on the supercharger. In the mean time, I took the supercharger front plate off and replaced the oil seal that the pulley passes through.
Re: Racing Saloon
That's going to spin up nicely 8-)
Re: Racing Saloon
Hi Johnboy,
Ran into a bit of a problem today. The original belt is 99 teeth and you can only get 98 and 92 teeth in the UK as far as I can see. I thought the 92 tooth belt would do the job but it is too tight.
I confirmed that 94 teeth is perfect and have ordered a 352L100 synchronous timing belt from a supplier in the US tonight. It should fit here:
Re: Racing Saloon
Never easy, is it chap :roll: hope it works out now ;)
Simonsud
Re: Racing Saloon
Post by Simonsud »
Can't you move the tensioner stud and use the 92
Re: Racing Saloon
Hi Simon Sud
Good thought but If I remove the tensioner wheel, the 92 tooth belt won't stretch over the two pulleys.
Re: Racing Saloon
been looking at this book over the last few months advertised in the back of the auto italia magazine, never got around to ordering it until now.
arrived today, fantastic book for the money.
5 pages on the 131 abarth in both stradale and rally Gp4 spec, some great pics too to inspire you mate :)
plus of course the 037, integrale, stratos, strada etcetc.....
http://www.auto-italia.co.uk/special-issue.asp
Re: Racing Saloon
Hi Kev,
Top tip thanks. I will order a copy.
Re: Racing Saloon
By George it fits!
The 94 tooth belt just went on:
And the dump valve fitment using the pop-off valve with the guts removed:
The engine runs well. Noticeably more supercharger noise. Just needs a dyno run now.
Re: Racing Saloon
can't wait to see, hear and maybe even have a ride in it Simon 8-)
Re: Racing Saloon
Sweet .Happy days 8-)
Re: Racing Saloon
Autoitalia, Brooklands - 29th April Kev?
Re: Racing Saloon
ooh, that sounds a tempter mate :)
Re: Racing Saloon
Looking good Simon. Glad to see it all went as planned.
Good luck with the testing. :D
Re: Racing Saloon
I thought I should test the dump valve before taking the car on the rolling road.
The testing was all a bit crude but quite helpful. Selected a socket for the manifold end of the dump valve pipe. Clamped the pipe around the socket and drove a cut schrader valve into the square drive and sealed it.
Then I pumped up the pipe with a bicycle stirrup pump.
The dump valve with the green spring opens at 5psi, blue spring 15psi and yellow spring 13psi. Valve operation is very smooth.
I realise that the manifold pressure is going to depend on air flow rate through the valve because with the green spring in place you could momentarily get nearly 20 psi if you slammed the pump handle down.
The conclusion I have come to is that the blue and yellow springs are too much and the green spring may be too little so I cannot achieve the 12psi I want.
I am going to dig out some large copper washers so I can shim up the green spring in the valve to get more boost if I need it during the rolling road session.
jobeed
Re: Racing Saloon
Post by jobeed »
A bit off topic, but I amazed at some of the ingenuity and engineering I read about on this forum, many times I have thought CAF could have put a good team together on that scrap yard challenge program. Worth bearing in mind if it's still on the telly, and unlike me you would be willing to appear on TV! Always wanted to be on the great egg race with Heinz wolf when I was a kid though!
This fiat looks ace by the way Simon! It's going to be a stormer!
Re: Racing Saloon
scrapheap challenge, there's an idea :D
Re: Racing Saloon
Kev - Fabrication
Shrew - Wheels & Exhaust
Lauren - Electronics
Keith - Finish
Bryan - Pilote
Engine?
Design?
Gearbox?
Elf n safety?
Works damager?
Re: Racing Saloon
:lol: :lol:
Re: Racing Saloon
that sounds like a great team line up :D
Re: Racing Saloon
Hi Guys,
I previously was getting 4-4.5psi boost.
With the new pulley I am getting 10.5psi and the car accelerates a lot quicker. I used my phone to video the boost gauge:
I changed the spring in the dump valve to see if I could get 0.8 bar and the 12.5psi I was after but it made no difference.
I am very happy with the increase and looking forward to seeing what the proper dyno figures are.
It should be 190bhp instead of the current 117bhp but it doesn't feel as quick as that. We will see.
Re: Racing Saloon
Hi Guys,
Changed the distributor this morning for a Bluetooth programmable one so the ignition can be retarded at high rpm and boost. This is the old one:
The drive gear was challenging to remove:
New HT leads and new plugs that are one step cooler due to the boost being increased.
The new HT lead from the coil to the distributor was not long enough so using the old one for now until I get a new replacement from Magnecor.
It started first turn but I didn't have time to play with the advance on my iPhone. An important step prior to the dyno session.
Re: Racing Saloon
Looking good Simon.
I took these today for you, sorry they are a bit blurred.
Crank
Re: Racing Saloon
Post by Crank »
Sharp enough to make me drool.
Re: Racing Saloon
Very cool cars 8-) 8-)
Re: Racing Saloon
Hi Keith,
Thanks very much. Lovely cars. Clear enough to see the carbs, exhaust manifold and the cam covers showing it is a 16v engine!
Lovely!
