drained coolant
drained coolant
ok , so instead of putting antifreeze in I just drained the coolant out of my 1500 sud, only water came out of one of the drain holes when I took the bolts out of each head, surly water should of come out of both heads, right?
Re: drained coolant
unless you were parked on a cliff, or removed the wrong bolts, i should say so melv
Re: drained coolant
should come out of both sides melv, get a screwdriver and prod the scum that's most likely built up under the side where you got nothing mate, but be prepared to get a wet hand!
