Alfa 155 white widey
Posted: Sat Nov 01, 2014 6:07 pm
by alfachris
The white 155 will be getting the diesel engine from the lhd 155 diesel over the next few weeks
The shell has had all the welding done and a full respray
The vemons are for the girlfriend's mk1 golf cabby
More 2mor
Re: Alfa 155 white widey
Posted: Sat Nov 01, 2014 6:34 pm
Good project Chris,
Glad to see this area get a bit busier too, but its down to you at the mo mate!
Keep it coming...
Posted: Sat Nov 01, 2014 7:21 pm
by alfachris
The 155 will have these bits on it
Eibach 26mm front and 22mm rear arb's
Bilstein shocks
Eibach lowering springs
6 line braided hose
16" speedlines in green lol
Silverstone rear spoiler with jack up kit
Dtm style headlights
Single wiper motor and arm
Tow bar
Black leather with 145 rear seats
Cd player, jbl speakers, sony crossover and amps
Battery in the boot
Posted: Tue Nov 11, 2014 12:23 am
by alfachris
Didn't get much done over the weekend.......fitted new heater valve, rear electric window loom, n/s/f seat belt, b post seat belt trims, 145 rear leather seats, dtm light inserts and hid's
Posted: Tue Nov 11, 2014 9:28 pm
by Veesix75
That's unusual in white, was that the original colour?
I always liked the 155, quick and capable.....Ive had 3 of them, think I will add one to my dream storage unit.
Posted: Tue Nov 11, 2014 9:50 pm
by alfachris
Veesix75 wrote:That's unusual in white, was that the original colour?
It was a 2.0 8v skinny in white. I've also a white V6 skinny
Posted: Sat Nov 15, 2014 10:23 pm
by alfachris
Fitted the boot lid wiring, boot carpet/sound deading, rear seat belts, inner c post trims, outer c post panel by rear screen, sony crossover into radio panel and 2 alpine amp's on a panel to go under rear shelf with wiring
Posted: Sun Nov 16, 2014 12:07 pm
by alfachris
Going to collect these today
Posted: Thu Nov 20, 2014 9:52 pm
by alfachris
Done a bit to it today dropped the rusty rear subframe out cleaned a few spots of little rust and treated it. Tuesday I started to remove the diesel engine and box out of the black 155 td.
Need the made engine loom 24" long as it will be going down the left chassis leg and connects to the engine on the right side.
Posted: Mon Nov 24, 2014 5:32 pm
by alfachris
Fitted rear subframe, rear wheels, rear brakes, braided brake hoses and under sealed
Posted: Thu Dec 04, 2014 6:06 pm
by alfachris
Removed the engine/gearbox from the black lhd diesel 155, fitted it into the white 155 with front shocks and brakes.
Also removed abs system as the diesel 155 didn't have it fitted
Posted: Sun Jan 11, 2015 10:23 pm
by alfachris
I've made a big error.........I didn't make any notes of wiring plugs have worked out what 3 out of the 4 plugs do...............so need to find a alfa 155 2.5 td workshop manual
Posted: Mon Jan 12, 2015 12:33 pm
Oops!
Posted: Wed Jan 21, 2015 10:57 am
by waynedear
C'mon Chris, bit of wiring, you can do that
Posted: Wed Jan 21, 2015 2:57 pm
by alfachris
waynedear wrote:C'mon Chris, bit of wiring, you can do that
I just need to find a wiring diagram of it
Posted: Wed Jan 21, 2015 7:46 pm
by alfachris
The 2.5td manual that i won on eBay.it in italian turned up today so now know what the 4 wires go to................so what to do finish this or V6 first ?????????
Posted: Thu Sep 03, 2015 8:18 am
by alfachris
All done now mot'd and taxed
Had a few problems sorting wiring and hoses out.
The shakedown drive showed up some more problems heater valve inside the car leaking, power steering leak, indicators stopped working and ticking over at 1700 rpm when warmed up.
Posted: Thu Sep 03, 2015 11:39 am
by alfachris
A few pics still need to fit the 145 QV side skirts
Posted: Fri Sep 04, 2015 7:22 pm
by alfachris
Sorted the first few problems out.
I used it to go to work today did 63 miles of the 70 mile trip and the water pump bearing went and seized so got recovered home by the AA
So now have find replacement
Posted: Sat Sep 05, 2015 8:27 am
Oops!
Posted: Thu Dec 31, 2015 9:22 pm
by alfachris
Sorted the water pump while ago in the end after finding out I need a earlier pump because the pulley was fitted on with a big nut.
Fast forward 4 weeks later alternators went............had to get replacement from Germany so now fitted it with a wiring modified. Ordered new heater resistor from eBay
