Hi chaps
Is it possible to swap my 3.0 qv 5 stud hubs and discs, for the 4 stud from a 2.0 ts, or another model/car?
I have some aftermarket wheels that are 4x98 pcd so im just looking at my alternatives other than redrill, adaptors, new wheels etc.
But i wondered if the driveshafts splines, bearings etc were compatible 3.0 to 2.0?
Thanks in advance
Hub Swap?
Hub Swap?
Re: Hub Swap?
Yes but a step backwards and lots of money in new 4 stud discs and brakes
Re: Hub Swap?
I'm not worried about one stud less from a wheel mount strength point of view, lots of cars with similar weight and more power cope with just 4 studs.
more concerned that the 5 stud hubs might have had different size bearings or different splines and shafts dimensions?
so they're a straight forward swap are they Simon?
Re: Hub Swap?
Not saying I know all the answers you might need every thing from a 4 stud model but easiest thing to do is find out part numbers for wheel bearings to see if they use the same ones , then you will know that you can just swap hub flanges and hope brake disc off set and sizes are the same
