Hall sensors
Crank
Hall sensors
Post by Crank »
As I had to change my seized alternator I took the opportunity to replace the cam shaft position sensor. I was getting the engine management issue light coming on ever more frequently and the fault code was for a faulty cam sensor.
The original Bosch one is much more expensive than most of the alternatives so I bought a Facet one as its only a magnet after all. However on comparing the replacement with the original Bosch one I could see the magnet is half the size on the Facet one. Does it matter? Will it therefore send a weaker signal, or does it mean it will fail more quickly as the magnet will loose its strength sooner?
I have, of course, also changed the belts, tensioners and water pump.
1976 1.5Ti
1977 1.2Ti
1989 1.7 Sprint Veloce
1989 75TS
2003 147 2.0TS Lusso
2004 MX5 1.8S
2002 1.6 Focus LX
Re: Hall sensors
I found my distributor would not advance when the magnet was put in upside down so it may have a big influence in your cam sensor. Good luck.
