Hi Guys
In my quest to fit the 20vt Coupe engine in to the spider . I want to swap the clutch from a Pull type to a traditional Push system. (This will give me more options for competition spec clutches) To this end I am in need of a 164 3.0 clutch slave cyl bracket along with the external arm and the vertical shaft that engages with the release bearing.
Regards
Lou.
164 clutch bits
164 clutch bits
