Magnets.
Posted: Thu Jan 11, 2018 11:55 pm
by Sud 145
Recently read an article regarding placing magnets around the oil filter to collect metal particles that may pass through the element. Seeing as drain-plugs are no longer magnetic what do you peeps think? Bet Lauren has some info'.
Re: Magnets.
Posted: Fri Jan 12, 2018 3:54 pm
by Johnboy
Sounds like I good idea .come on Lauren . What do you think
Re: Magnets.
Posted: Sat Jan 13, 2018 7:56 pm
by Spacenut
I wouldn't know - we don't use reciprocating engines in space
I'm quite sure that sticking magnets on the oil filter case would attract ferrous metal debris, but wouldn't the filter strain that out anyway? Even if the filter was completely clogged the by-pass valve would only allow the contaminated oil to flow back to the sump.
My only worry would be the filter clogging with bits of metal if you put magnets around it. There again, if there was that much metal filings in the engine oil you would have more to worry about than just a clogged filter!
So yes, I suppose it would be an idea to collect a few filings in the filter, which could then be disposed of at an oil change.
Re: Magnets.
Posted: Sat Jan 13, 2018 10:56 pm
I'm in agreeance with Lauren on this one, seems a logical thing to do but in practicality would it solve anything/ Like the low oil pressure light, by the time it's on your engine is usually toast!
Why not ad a magnet to the sump plug?
That'd be the easier solution and would catch any filings before the oil pump had chance to chew them up..
Re: Magnets.
Posted: Sun Jan 14, 2018 12:27 am
by Sud 145
Yep think I'm gonna give that a go Kev.
Re: Magnets.
Posted: Sun Jan 14, 2018 1:15 am
by Johnboy
So if you make the Kessla Run in under 13 parsecs would that help ?
Re: Magnets.
Posted: Sun Jan 14, 2018 11:02 pm
by Spacenut
Only if you zap Womp Rats in your T16
Re: Magnets.
Posted: Sun Jan 14, 2018 11:11 pm
by Johnboy
Re: Magnets.
Posted: Sat Jan 27, 2018 3:06 pm
by Sud 145
Update. Managed oil and filter change before the rain came, it turned out that my drain-plug is slightly magnetic but added a magnet to it and stuck two on the sump. Homer Simpson moment - don't run car off the blocks without removing drain-can first. DOH.
Re: Magnets.
Posted: Sat Jan 27, 2018 3:17 pm
by Johnboy
Woops
Re: Magnets.
Posted: Sat Jan 27, 2018 6:00 pm
We have all done it mate.
