1700 8v now sold
Posted: Sun Apr 09, 2017 6:07 pm
Evening all
I'm having a clear out and have a complete(ish) 1700 engine. As you can see its an 8v hydraulic tappet engine code AR 30550. This puts it as being a 33 1.7 ☘
It has a flywheel but no clutch and I would recommend a strip clean and rebuild it was a carbed engine and ut has the manifolds and I can supply enough bits to build a linkage but no carbs ( would of been fitted with 40s ) I know some people are asking daft money for these . Make me an offer
Re: 1700 8v
Posted: Tue Apr 25, 2017 6:55 pm
by sudboy1490
Hi am looking for a 1.7 block. You say it just needs a strip and clean, does that mean the block internals are good and it doesn't need bearings or rings etc?
Have you heard it running?
col
Re: 1700 8v
Posted: Tue Apr 25, 2017 8:00 pm
Hi Col
I would of heard it run but it was many many yrs ago ( i stripped loads of 33s in the late 90s due to rust ) . I have no reason to believe theres anything wrong with it but i have to recomend its stripped and checked for piece of mind id personaly id always fit new shells as a matter of course and give the bores a good hone. This one doesnt look like its ever been apart so is unlikely to be anything but std on the mains or big ends.
If you only after a block i also have a 1.7 short motor ( block crank rods and pistons sump front and rear covers flywheel) ?
Louise
Re: 1700 8v
Posted: Wed Apr 26, 2017 8:48 am
by sudboy1490
So I presume the short motor is in as good a condition as the full motor?
I'll pm you for further detail
Col
Re: 1700 8v
Posted: Wed Apr 26, 2017 9:00 am
Hi Col yeah i guess it is . I do have several bare 1.7 blocks aswell and an old 89mm race block
Re: 1700 8v
Posted: Wed Apr 26, 2017 9:27 am
by sudboy1490
So no internals with the bare blocks Inc the 89mm block?
Col
Re: 1700 8v
Posted: Wed Apr 26, 2017 12:07 pm
No buf i do have a spare 1.7 crank
Re: 1700 8v
This engine now sold
Re: 1700 8v
Posted: Wed Apr 26, 2017 12:24 pm
by sudboy1490
Is the 1.7 short motor still available?
How much do you want for it?
Re: 1700 8v
Posted: Wed Apr 26, 2017 12:50 pm
Hi Col
Id take 250 it turns over but its a little tight as its been stood for many years without heads on it . if you like i can strip it for inspection and ill drag a hone down the bores for you
Re: 1700 8v
Posted: Wed Apr 26, 2017 1:01 pm
by sudboy1490
I'd need to ship it to the north east as well lou so it might well turn out to be a little rich for me considering it'll need a refresh as well
Sorry, col
Re: 1700 8v
Posted: Mon Sep 25, 2017 8:28 pm
Due to change of plans this engine is now still available. 1700 8v from a 33 GCL. turns over nicely and largely complete no cadbs or Dizzy but will include linkage
£400
Re: 1700 8v
Posted: Tue Sep 26, 2017 11:09 pm
by Alfastrut
What's your location?
Re: 1700 8v
Posted: Tue Sep 26, 2017 11:18 pm
Hi Alfastrut I'm in Staffordshire ST15
Re: 1700 8v
Posted: Wed Sep 27, 2017 8:54 pm
I might be going there myself soon'ish if the engine relayed back to Nottinghamshire makes it any easier for you alfastrut?
Re: 1700 8v
Posted: Wed Sep 27, 2017 9:14 pm
by Alfastrut
Thanks for offer petrolhead but going to pop down myself
Re: 1700 8v
Posted: Wed Sep 27, 2017 9:22 pm
Great stuff,
Have you come to an arrangement? :P
Re: 1700 8v
Posted: Sun Oct 01, 2017 12:52 pm
It is Now SOLD .
Re: 1700 8v now sold
Posted: Sun Oct 01, 2017 4:49 pm
by Alfastrut
Thanks loo
Posted: Sun Oct 01, 2017 5:02 pm
:) your welcome Craig
