164 QV Air Flow Meter, Bosch 0 280 203 026 Required?
Hi all
It would appear that the Air Flow Meter on my 164 qv has a dead spot that kicks in at 2500rpm, creating the mother of all stutters and misfires :shock:
Ive split the top case to inspect it and attempt a refurbishment but i think i'm pee'ing in the wind to be honest, so has anyone got one of the old mechanical flap type AFM hanging around?
Maybe even to try first of all to make sure its that AFM giving me this symptom but i'm pretty sure.
The bosch number is 0 280 203 026 and is shared with a couple of fiats and the porsche 944 i believe.
Thanks in advance
Shrew
Simonsud
Re: 164 QV Air Flow Meter, Bosch 0 280 203 026 Required?
Post by Simonsud »
I'll check the part numbers on the ones I've got I think they are Vauxhall ones from gte or Sri
Hi Simon
and thanks very much, But, i think io can save you the time and trouble if they are vauxhall models.
the bosch afm fitted to the 164 qv is almost unique but for a couple of Fiats and Lancia's, and the Porsche 944 2.5 turbo!
Crappy German deisgned parts, made in France, poor Alfa didn't stand a chance,
I smell a conspiracy! :lol:
Simonsud
Post by Simonsud »
I did have a Porsche 944 turbo one from a 1989 silver rose 240 Bhp model but not sure if I kept it that's why I will check part numbers
Simonsud
Post by Simonsud »
I've found one of the air flow meters but it's the wrong one and has five wires and air temp sensor I will look at work for Porsche one as I've got some other bits from it so it might be hiding there
Thank you Simon, much appreciated :P
Simonsud
Post by Simonsud »
No luck so far I've got two koni coil over front struts for 944 turbo I thought air flow meter might have been stashed with them but it's not I'am afraid to report
Thanks for looking simon,
Much appreciated anyway, better luck next time! :P
