My S1 Sud Ti
Re: My S1 Sud Ti
Brilliant work as always Kev. I have to ask though (as I will be using the same trick very soon), what are you doing about overspray on the thermometer? Or do you take it out of the box while you spray and then put it back in afterwards? It's looking a bit grey now, is all...
Re: My S1 Sud Ti
Spacenut wrote:Brilliant work as always Kev. I have to ask though (as I will be using the same trick very soon), what are you doing about overspray on the thermometer? Or do you take it out of the box while you spray and then put it back in afterwards? It's looking a bit grey now, is all...
it does seem to end up getting overspray on it lauren....guess i should really clean it off every time i use the box, but i never do
one of these days it'll get so covered it either won't be readable or won't work
Re: My S1 Sud Ti
day off work today, un-planned as had an extra day to get in before xmas so nothing really scheduled.
thought i'd try and do the slam panel repairs seeing as the weather was pretty mild.
doing it on the driveway though brings issues with overspray and the paint doing a 90deg turn before it hits the panel so thought i'd try a bit of extreme oven painting
took the sud out, turned it round and poked the nose under the frame. this allowed the front end to be masked out and leave me in the relative breeze free workspace
Re: My S1 Sud Ti
both sides of the slam panel had been damaged when the bonnet was fitted, bolt heads had dented the panel as the hinges should have been the flush welded type, not the bolted on ones.
filled the dents then primed
Re: My S1 Sud Ti
basecoat & lacquer done
couldn't have possibly have doen it within the extreme oven, as seen in garden sheds in cardboard box from
a tip for if you don't want to leave a masking line but can't get behind an area is to leave 5mm or so of the masking tape peeled over, don't press it all down. this leaves a soft trap that when sprayed leaves a soft edge without giving the game away
Re: My S1 Sud Ti
sorted out a few more bits under the bonnet too.
heater box top fitted
brake lines clipped into place
built up the refurbished hand-brake lever and fitted that
remarkably i now have a sud that will hold on my driveway with it's own hand-brake! never had that before
i'll refit the bonnet next week once the paint has had a good chance to harden off fully, not like i'll have much time over the next few days anyway
i've modified the hinges and using different bolts to ensure that the same dents aren't repeated
all in all chuffed with the days work considering i'd not planned to do anything
sudboy1490
Re: My S1 Sud Ti
looking good kev
i seem to remember you saying it has a windscreen surround from a hill avenger? my blue one has the same one and to be honest theyr not a good seal, it leaks quite badly in the driving rain. Mind you iv not bothered to try and seal mine in anyway as am frightened of any water getting trapped in there behind the rubber!! The way it is now it drys out really quickly..
Re: My S1 Sud Ti
Top work as ever Kev, but you have to do something about that tailpipe!
Ian
Ian
Alfa Mito 1.6JTDM-2 QV Line
Re: My S1 Sud Ti
Looking really, really good Kev.
You should be very proud of yourself.
All the best rsfruitbat
Re: My S1 Sud Ti
cheers guys, starting to see the light at tunnels end now
not sure about the screen seal being an avenger one col?
tailpipe will be adjusted before long ian
cheers ade, coming together nicely now after the hard work was done by others before i got it so although chuffed so far it isn't like i've done a big resto on this one. still happy to have got an S1 ti after all the years of searching
Re: My S1 Sud Ti
Sorry guys,
I mentioned a chap talking to me at an Autoitalia meet. He told me that the early bonded screens, if replaced, were sometimes put in using an Avenger rubber. How true it was I do not know but he claimed to work in the day at a dealer
It also enabled the fitting of a chrome trim.
Re: My S1 Sud Ti
could well be true mate, can't recall hearing it but may well be true as a seal is a seal.Kegsti66 wrote:Sorry guys,
I mentioned a chap talking to me at an Autoitalia meet. He told me that the early bonded screens, if replaced, were sometimes put in using an Avenger rubber. How true it was I do not know but he claimed to work in the day at a dealerIt also enabled the fitting of a chrome trim.
hoping mine doesn't take on the proportions of a sieve........
Re: My S1 Sud Ti
The avenger windscreen seal is correct. think mk1 cortina can be used aswell. I was told by the owner of Templar windscreens. This is the guy who started autoglass and then flogged it, got bored and started a new firm. He new a lot about what fitted what.
Kev - you may not have done the welding but you most certainly have put your mark on this rebuild by virtue of your attention to detail and perseverance to get things right. Take the credit for the excellent job you are doing!.
Re: My S1 Sud Ti
had an hour or 2 to spre this afternoon, family didn't fancy a ride out to skeggy....who am i to argue
fitted the painted & modified bonnet hinges then popped it back onto the car. needed a little bit of fettling to the drivers side hinge to get the edge gaps right enough but got there in the end.
you can see from the closed bonnet pic how close the hinge plate sits to the front upper panel which with ordinary bolts were fouling the panel, denting it even. with the new tapered cap screws which with the tapered seats cut into the hinges fitted it all now sits flush, just enough clearance
meant i could finally fit the grille that's been in the house for safekeeping after i painted it weeks ago
little steps
little steps
Re: My S1 Sud Ti
Making good progress Kev,
Have you managed to find new seals to go round the engine bay?
Re: My S1 Sud Ti
was gonna have a look in my box of seals mate, in fact i measured it up....then forgot to look when i got in the shedBluesuit wrote:Making good progress Kev,
most likely will go to woolies to get some new door seals so will get some new bits then, or thinking about it i'll get some off the trimmers when he does the roof lining. he's bound to have some?
Re: My S1 Sud Ti
Kev, I trust you have checked clearance with the grille fitted now the bonnet is on.
Mine caught the first time and nearly scratched the paint
She is looking good.
Re: My S1 Sud Ti
took ages to ensure the neccesary clearance mate, amazing how far down the bonnet lip comes isn't it!Kegsti66 wrote:Kev, I trust you have checked clearance with the grille fitted now the bonnet is on.
Mine caught the first time and nearly scratched the paint![]()
leaves a hell of a gap when the bonnet's down though.
first fit i could see it was gonna foul, prayed i hadn't chipped the paint on the bonnet lip.
Re: My S1 Sud Ti
Glad I am not the only one.
Re: My S1 Sud Ti
fitted the front grille badge properly now, bought some plastic sleeves that took out the wear in the retaining pins. of course double sided tape would have held it there but as we know, you need to take the badge out to get to a grille retaining screw..
other little job was to clean up the rear light reflectors that rich kindly gave me a while back, cheers again mate
i'm sticking these in place with 3M double sided tape rather than with the retaining pegs (ok, that'd be tricky as they've broken off...
) as it will keep any moisture from entering the car there.
not a great deal else planned now, details really.
want to get it as near as possible done before it goes off to have the roof lining made which will hopefully be late feb, fingers crossed
Re: My S1 Sud Ti
Happy New Year to you Kev.
Noticed the new "thingy", what's with the NZ 27 ? Is it a bike number?
My reflector pegs were dodgy, just a thought, but I stuck mine with clear silicon as they are quite translucent. It also helps keep the wet out.
Did anything come of the multiple headlining order, or is it still in the pipeline?
All the best.
Keith.
All the best.
Keith.
Re: My S1 Sud Ti
27 is the race number of the best bike racer of recent times, casey stoner
read is autobiography which i got for xmas.
just confirmed what i already know. a guy who says it like it is, doesn't get into the PR BS that other self proclaimed "stars" do
i like him.
the roof lining thing seemed to fizzle out, also mine having the webasto roof kind of put me aside from the group buy.
a local trimmers who have done great work are doing the roof lining late feb/early march. not only the roof lining but they are taking the webasto apart and doing the lining to that in the same new material so it matches for colour etc. they are also going to re-cover the outer black vinyl top too.
not cheap but should be worth it
i like him.
Re: My S1 Sud Ti
Should look nice, like you say, it will all match nicely.
I seem to remember in a past thread your support for Stoner.
Looks like you had the beach to yourself on New Years day.
Numbers seem to be growing for "Suds in the sun". We may have a southern convoy
Re: My S1 Sud Ti
Regarding the group buy for head linings: I have it on my to-do list to contact Alfaholics after 5th Jan when everyone should be back at work.
Will report back to interested parties as soon as I have spoken with Alfaholics.
Sorry the enquiry did not get made before Xmas but I was away in Portugal for three weeks. I think I am right in saying that there are 3 interested parties including myself now if Kev is having one made elsewhere.
If anyone else is interested in joining in please PM me.
Re: My S1 Sud Ti
yes mate, sorry to opt out.
did have some concerns about whether me having the full width folding webasto roof would be taken into account so took the plunge when a professional became an option
for anyone that has an S1 sud though the one on kieths car loks awesome
its_welshy
Re: My S1 Sud Ti
You're doing some truly amazing work Kev.. What a beautiful looking Sud
Ted27sud
Re: My S1 Sud Ti
And there was I, Kev, thinking it was because of my Sud and me....!KevJTD wrote:27 is the race number of the best bike racer of recent times, casey stoner
Re: My S1 Sud Ti
Awesome Car, this is looking absolutely fantastic Kev.
Jon
Jon
Re: My S1 Sud Ti
you know you'll always be the number 27 of choice on 4 wheels ted
vecchioalfa
Re: My S1 Sud Ti
Car is looking good Kev, it looks really nice in that Silver, it goes really well with the mixture of stainless and black trim that these cars have, top job
