Seat belts
Seat belts
Has anyone got a full set of rear seat belts for a S3 Sud Ti.
Re: Seat belts
Securon type 200 (3 point static ) will fit.
I've recently fitted a pair
Re: Seat belts
Thanks Dave. I’d Ideally like to Find original inertia reels if possible but 3 point statics would be Suitable alternative. If I can’t
Alfastrut
Re: Seat belts
Post by Alfastrut »
Did they do the inertia ones in the rear for suds? I fitted a 33 inertia to mine. Had to weld a nut to the wheel arch to mount it. I've some off the none inertia I think.
Re: Seat belts
I’m pretty sure I remember seeing inertia reel belts in the back but i may be wrong . It was along time ago.
Re: Seat belts
My S2 sud 3 door has factory 7/16 UNF mountings for rear 3 point seat belts.
Bottom 2 are under the rear seat.
Upper one (where i presume an inertia reel could be mounted?) is on the rear 3/4 panel behind the side window.
Alfastrut
Re: Seat belts
Post by Alfastrut »
I've one of each in mine. Would you like photos?
Re: Seat belts
Yes please Craig .
Alfastrut
Re: Seat belts
Post by Alfastrut »
Here you go loo
Re: Seat belts
Thanks Craig. So you’ve got one static and one inertia reel. .
Alfastrut
Re: Seat belts
Post by Alfastrut »
Yep. I only had one child seat to fit. That's why I put the one 33 inertia seat belt in. This was 25 years ago.
Re: Seat belts
LOu,
have a look at Ebay item 224035882762
Full set of 33 belts, but will prob split
