1974 Alfasud Trofeo
Oxfordshire driver
Re: 1974 Alfasud Trofeo
Post by Oxfordshire driver »
A 4 second saving...hold the lettuce :!:
blimey, that's a nasty break, could have been a real disaster without available run-off space :o
all this extra pace you're now putting through it, fantastic lap time improvement 8-)
Wow....I'll be checking mine !
It's the front arm that usually cracks, worth checking those for fatigue.
That's a great lap time, my best is 1:43 way back in 2007.
:o Bloody 'ell Simon, you don't do anything by half !!
Cracking results (including the repair)
Team Tangerine will be over Sunday. 8-)
Post by Marlow Sud »
Hi guys,
Some things put a smile on your face beyond all importance.
My spare wheels came back from refurb today, cracking job. While being diamond cut they have managed to keep the wheel size and Speedline name.
Should look great on the car.
Very nice.....just need to keep off those nasty sausage kerbs :D
Lovely job done there Simon.
They look very smart.
Hi Guys,
There was a spare engine with the Trofeo and I was not sure what it was.
I took the cylinder head off and it is 1512cc and it looks like it is high compression and has been gas flowed and polished but standard valves at 38/33mm?
Everything looks overhauled with new pistons, polished rods and polished crank plus a baffled sump.
Might be wise to fit some ARP big end bolts though.
Are the Pistons std and do the cams look reprofiled ? 1512cc is +4 I think.
I have a 1700 engine with 38mm valves, it gave more torque but a similar top end power to 40mm but that was mild tune not race.
My other 1500 engine is all std components, I think 40mm valves and reprofiled cams and that gave good top end power so you probably still have a powerful engine there.
Hi Tim,
Thanks for the info. The pistons are stamped 84.6mm
I don't know what a re-profiled cam would look like? The valve lift is 9mm if that helps.
I have been trying to work out the compression ratio but I am getting awfully high figures. Back to the numbers to try again.
+6mm in that case, got my maths wrong!
I can't remember what std lift is, but I know some reprofiled cams that were described as full race were well over 10, I think 10.9.
I have two old sets, one single lobe and one twin lobe. I'll see if I can dig them out as I'm sure they are stamped....however the high tens are what I remember
Having said that, the lift gives power but no end low like the trofeo, so just like the SC Sud, an all rounder still drives very well.
Just a random document.
http://www.jdmcars.com/tech/lift_duration.pdf
Thanks Tim.
I read that bigger valves and more valve lift both increase the flow rate in the head linearly up to a limit of course.
My latest calculations come out with a compression ratio of 10.8 : 1 which I reckon is not far out.
Those cams look proper high-lifty to me. Base circle diameter looks smaller than stock, so may be re-profiled lobes rather than a new forging.
But very nice all the same - proper old skool engineering. Very envious 8-)
Hi Lauren,
Just ordered a king size mattress plastic bag and 4 x 1kg bags of desiccant.
Engine and desiccant in the bag.
Suck out all the air with a vacuum cleaner and twist the bag neck and ty-wrap the neck back on itself to seal the evacuated bag.
Should keep the engine nice and corrosion free while in storage. I will probably re-oil the camshafts and cylinder bores first.
Marlow Sud wrote:Hi Lauren,
You know what, I've always wondered about the best way to store a freshly built engine.
That's a great idea :)
Can see the integrale engine build being done this Winter now..... ;)
I quite like this. I think I should make a video :shock:
https://vimeo.com/163817209
Very good.....except I wouldn't be letting it get gravel rash on that lane.
Maybe we should hire Blyton for a day and make a combined video, racers and road goers .
In fact I'm checking hire costs now (which have probably quintupled since ginetta bought it)
Boo.....the track hire link has been disabled.
Ted27sud
Post by Ted27sud »
We've all heard that old chestnut 'Drive it like you've stolen it' haven't we? Does that include Trofeo Alfasuds as well.........? :D :D
Taken from this month's Motor Sport magazine.
Ted
i've got some knobblies if anyone ones to borrow them :D
What you have to do to get in Motorsport Magazine! :oops:
You need to ask them for a copy of that Simon. Fantastic shot, even if you weren't enjoying the moment :D
Good idea Keith. I will ask them now.
Great picture !
leading the way in Novembers auto italia magazine ;)
That tells a story Kev.
I am sideways in the gravel and Ted is going round Ferraris.
Nice one. Like that picture much better.
Hi Guys,
Just been sent some pictures from Brands Hatch.
Silverstone this weekend for the final two races of this season.
Good picture Simon.
We plan to come over on Sunday.
Excellent. I look forward to seeing you. We have
Alfasud SC, Alfasud Sprint, Trofeo and Golf.
Saturday looks wet.
BS25
Post by BS25 »
Hi Simon,
Good luck to you all down at Silverstone - I'll follow progress on TSL. Have fun!
