Rebuilding water pump.
Re: Rebuilding water pump.
Stane Street - A29.
Any thoughts on what I should do for gaskets. Will go over it with a grnder and wire brush first but was wandering if just a greased paper gasket would do. Thoughts please as there is not a Classic water pump forum.
That flange looks very similar to those I had on a steam boiler in my previous job. Cochranes made the boiler but you should be able to source them from a commercial outlet - neoprene ones are the best.
How about Leather they used to make foot pump seals from leather Before the advent of modern rubbers
Excellent ideas, had no idea about neoprene. Thank you.
I've used neoprene for many similar tasks, good enough for wetsuits
Cheap too
Cheap too
Yep. spoke to a chum last night and he said `Just bought some rubber sheet for sealing a bin.'
So got some off cuts coming. Your right it is cheap stuff. Rare it works out that well !
Now working, though had a lot of talk about head injuries while holding the heavy top up a ladder while it was being bolted to the 40ft shaft we were trying our best not to lose down the hole. You can imagine there was no time for photo's.
Well done , looks great, nice to see you made it work
Thanks. Will just wait for the storms to stop and then paint the rest of it, then new bolts all round once the shop opens.
Also just need to keep pumping till it clears as still a lot of sediment in the system.
Hard work as well pumping the 40ft shaft up and down.
To think of pumping water for livestock, horses and the home makes me realise what an easy life we have.
See, not quite drinkable yet !
