Now there is helicoil repairs but I'm not convinced about them as it's just a rolled piece of stainless threaded in, I've had these pull out of jobs with the bolt before where previous repairs have been done. I'm sure if it's just for a fit and forget repair then that would be fine, as long as the bolt wouldn't need to be taken out again.
So what else to do?
When the neighbouring one did this to me when the engine got rebuilt I drilled it out and tapped in a bigger hole and used a long stud so I could use a nut so as not to have to take it out of the alloy again. This isn't ideal as the bracket and spacer needed reaming out to suit the new stud size plus it makes it more awkward for fitting the bracket back on. Making two studs would double the difficulty.
I searched for an alternative and came across a system by Wurth called time-sert which matched my concerns over helicoil.
An expensive kit but thankfully I managed to borrow a kit, thanks again.
![Cool 8-)](./images/smilies/icon_cool.gif)
You start off by drilling out the damaged thread with the supplied bit.
Right hand side hole of this poorly taken picture!
![Laughing :lol:](./images/smilies/icon_lol.gif)
Then the tool in the kit is used to cut a recess in the face, there's a stop in the tool so you know when it's deep enough, this is for the flange on the inset so it sits flush and doesn't go in too deep.
Next the supplied tap is used to cut the new thread for the insert.
