16V cam specs
16V cam specs
Does anyone have the specs on standart 16V camshafts?
Re: 16V cam specs
You might find it all here mate:SteffenJ3316V wrote:Does anyone have the specs on standart 16V camshafts?
http://alfaromeo33.extra.hu/
Re: 16V cam specs
Thanks mate but it's 2500 pages and I can't find it there
Re: 16V cam specs
There is no cam specs in that materiel Only minimum lift. Anyone knows the duration etc?
Re: 16V cam specs
SteffenJ3316V wrote:There is no cam specs in that materiel Only minimum lift. Anyone knows the duration etc?
found it
Re: 16V cam specs
Thanks Kev I did find that but i don't know what to do with that information. What I'm looking for is how much they lift the valves eg 10 mm and the duration on the cam eg 282* @ 0,1 ,mm lift
Re: 16V cam specs
from the pics the diagram can be followed to calculate the cam duration.
so for example,
inlet cam lobe "a" starts at 8 degs before top dead centre (tdc), continues through 180 degs and finished at point "b" 48 degs after bottom dead centre (bdc) although there is a mis-print in the diagram spec as it lists it being after tdc which is wrong.
so the specs are
inlets
236degs & 263degs (both lobe pairs are timed differently, start/close & duration)
exhausts are both 244degs although they open & close at different points
valve lift is also different per lobe on inlet side, one is 9mm & the other 9.5mm
exhaust lift is 9.2mm on both lobes
so for example,
so the specs are
inlets
Re: 16V cam specs
Thanks Kev You're a star
