Anyone got a 1500 block?
Posted: Fri Jan 19, 2024 5:58 pm
by chriswilliams
I want to buy a 1500 boxer block. Does anybody have a spair one they would like to get rid of?
Regards
Chris.
Re: Anyone got a 1500 block?
Posted: Fri Jan 19, 2024 10:50 pm
I may have one Chris. Let me check,over the weekend Lou
Posted: Fri Jan 19, 2024 11:02 pm
by chriswilliams
Thanks Loo.
Regards,
Chris?
Posted: Sat Jan 20, 2024 1:52 pm
by StescoG66
Not got a 1500 but have a 1700 if it’s of use to you.
Posted: Sat Jan 20, 2024 9:42 pm
by rsfruitbat
What ya gonna do with it ?????
Posted: Sun Jan 21, 2024 10:47 am
by chriswilliams
The last block I used had some rust in the bore. I removed most with the hone, but clearly not enough or I went too far. I have low compression on that cylinder.
I want a block I can transfer everything to without extra work.
It's for a Minari that I want as a track car.
The 1700 would be interesting in the future but I am not ready for that yet!
Chris
Posted: Sun Jan 21, 2024 10:48 am
by chriswilliams
Thanks loo but I am not ready for a 1700 just yet.
Chris
Posted: Sun Jan 21, 2024 11:04 am
Hi Chris. I’ve sent you a PM about a 1500 bottom end
Posted: Sun Jan 21, 2024 7:55 pm
by rsfruitbat
Hope you find what you are after.
Worst case is you could get that bore sleeved?
Posted: Mon Jan 22, 2024 3:46 pm
by chriswilliams
Explain? I assumed a full rebore and oversized pistons?
Chris.
Posted: Mon Mar 11, 2024 10:27 pm
If there are a good source of 1700 parts available, you could build the 1600cc screamer?
Most who did it, liked it, and i'm sure LouLou can probably explain it and supply it!
Posted: Mon Mar 11, 2024 10:35 pm
Funny you should mention that Shrew. I’m actually thinking of reworking the 1500 (1525) I built in to a 1600. It’ll actually be 1634 as the 1500 is 85mm (1 mm OS)
Posted: Tue Mar 12, 2024 8:00 pm
by chriswilliams
What mixture of parts = 1600 screamer? Sounds interesting.
Chris
Posted: Thu Mar 14, 2024 12:54 pm
by justsuds
87mm bore - 1700 pistons, - with a 1500 ( 67.2mm stroke ) crank, - the 145 / 146 1.6 boxer engines did it the other way, with 84mm bore and 72mm ( 1700 ) crank, - short stroke = revs !
If you still need a 1500 block I'm sure I will have one, - let me know if you do.
Posted: Sat Mar 16, 2024 10:29 pm
by chriswilliams
I get the 'screamer'. Interesting idea. I will stick with the 1500 for now.
John. I am still interested in a 1500 block if you have one?
Chris
Posted: Tue Mar 19, 2024 10:36 am
by justsuds
pm sent Chris, thanks, John.
Posted: Sun Mar 31, 2024 4:53 pm
by chriswilliams
Bought from John at Justsuds.
Good price.
Thanks John.
