I found a diff and loads of gear cogs, some have got water contamination but the diff looks ok and would clean.
Can anyone identify the type from the code stamped/cast on it in the title ? Or is that just the casing part number
I thinks it’s a 1200ti but not sure
Diff 101473 6M
Re: Diff 101473 6M
Hi Tim can you read the numbers stamped into the crown wheel ?
Re: Diff 101473 m6
Well, it may be a mute point, after I asked the question I went back to look at the diff and after staring at it for a few mins realised there wasn’t a crown wheel attached.
Looked in the tub of random cogs and gear stuff and said crownwheel was there, complete with sheered off bolts still inside the threads.
It came back to me it was a blown up gearbox I kept in case any bits were salvageable.
I’ll take a look when I go in the shed just to be sure.
