I have 1.7 crankcase that the main bearing were rotating in when racing. So we did not use it on my build.
Is it scrap then, or is there a chance would someone be interested at some point ?
1.7 crankcase
Re: 1.7 crankcase
Don’t chuck it !!! As long as the journals are still within spec it’ll be fine
I’ve rebuilt engines in the past that have suffered from spun brgs with no problem.
Re: 1.7 crankcase
Did some engines get the journals line bored for stronger (Cosworth) mains?
Re: 1.7 crankcase
Super, that's what I needed to know. A good reason next time it catches my ankle, not to chuck it.LooLooSud33Spider wrote: ↑Thu Jan 21, 2021 9:27 pmDon’t chuck it !!! As long as the journals are still within spec it’ll be fine
Thank you.
