Steering Rack
Steering Rack
Been a silly boy today.
There was a small amount of welding needed to the bulkhead floor on my car, near the servo.
The guy must have plated up the drain hole.
Water was gathering, so I drilled a new hole.......the drill bit damaged the plastic tapered end cap on the steering rack!
Are these a removable item...and can I get one?
Re: Steering Rack
Dave is it the long “black Dick” one in the RH side (sticks through the inner wing). They come off quite easily just give it good tug and wiggle. I’d Just take it off and plug the hole with some decent goop
Re: Steering Rack
Lou,
Yes you are correct regarding the LBD!
But I need to replace it somehow?
Plugging the hole, I don't think is the answer?
Re: Steering Rack
It's just a dust cover that keeps the rack clean as the toothed rack end comes out as you turn, it's not under any pressure or anything.
It does just pull off as Lou suggests, then you can either repair it using araldite or something similar. Or alternatively I'm sure jutsuds John would send you out a good used one.
Re: Steering Rack
They used to regularly fall off. I’ve got some NOS ones for the power assisted racks (they’re different from Non assisted). Seriously unless it’s a BFO crack or it’s shattered into gazzilion bits covering a small hole externally will be fine the rack doesn’t pressurise the LBD
And you just want to stop shoite and crap getting in. Failing that I’m sure John will have some
Re: Steering Rack
Sorry, didn't explain myself properly.
The drill bit hit it, and broke half of it off.
Looks a clean ish break.
So, if I can get the other half off, I may be able to repair it.
Re: Steering Rack
They are hard plastic Dave, so super glue and a wrapping of pvc electrical tape should be ok.
As Kev and Lou have said ,it is just an extended dirt cover for when the rack extends out.
Re: Steering Rack
Yes, hard plastic Keith.......the end just broke off and was left inside!
Re: Steering Rack
Managed to hook the broken bit out.
Just need a replacement now from John
Re: Steering Rack
There's one in the post today Dave, - unless you are coming over for a 33 heater !
Re: Steering Rack
Thanks John,
I bought a 33 heater from you some time back.
Had a look at fitting it, and declined!
I'll need to dig out the car coat, trilby, and driving gloves!
We had an Austin A35 years back. Got an original sales brochure at an autojumble.
There were 2 optional extras. A heater!!
Guess what the other was?
Re: Steering Rack
Fag lighter ?alfadave wrote:Thanks John,
Re: Steering Rack
Adjustable drivers seat (slider) ??
Re: Steering Rack
No Lou!
I thought you had an A35, and would know the answer
Re: Steering Rack
Flip out indicators, from the upper door pillars ?
Re: Steering Rack
Ash tray?
Re: Steering Rack
Ash tray is the correct answer!
It was a crappy tin thing screwed under the front shelf.......would have thought they could fit it as standard.
A friend used to get a lift years ago, every Mon/Fri to work away in Newcastle.
In an A35 with no heater.....car was well steamed up when they got there.
And they were well steamed up in the pubs the rest of the week!
