Sprint lights
Sprint lights
Quick question...are the Sprint S3 Carello inner lights sided? Thanks in advance
Re: Sprint lights
Hi Richard I don’t believe they are I’ve got a s/h. set somewhere if I can find them I’ll have a look
Re: Sprint lights
I don’t think so as the beam pattern is flat I think whereas the outer have a \_ pattern - or _/ for left hand drive..
Re: Sprint lights
Thanks. Just trying to get a pair of lights together for a friend so I don’t have an actual car to check. I have a knackered grill that I cleaned up and screwed to my office wall for the hell of it and I noticed the clip patterns are different which got me wondering if they’re sided in terms of the fittings?
Re: Sprint lights
Yes they are because the lights have 3 fittings on the back, so cannot be swopped from side to side.
Re: Sprint lights
Thanks, makes life a little more complicated lol!justsuds wrote:Yes they are because the lights have 3 fittings on the back, so cannot be swopped from side to side.
Re: Sprint lights
Why didn't they make them both the same!
Maybe you could make an extra cut out?
Re: Sprint lights
It would have been easier for everyone concerned if they had been the same instead of sided. I think it would be easy to cut an extra hole if push came to shove!alfadave wrote:Why didn't they make them both the same!
