Oil pressure gauge sender
dave.armstrong
Post by dave.armstrong »
I have just replaced the oil pressure sender unit on my Sud with this one I got from Ebay
https://www.ebay.co.uk/itm/Genuine-Kerr ... SwcnpdSuHC
It works great and is the correct thread and pressure range.
The only thing is that it does not earth through the body so you will have to attach an earth lead.
The good thing is that there is an earth point just near where it fits.
Great for £8.06 and works well.
Alfastrut
Re: Oil pressure gauge sender
Post by Alfastrut »
Thanks for the heads up Dave. I will be purchasing one of those
Good find Dave, nice one. ;)
Alfastrut
Post by Alfastrut »
Purchased and fitted. Never had the Guage read such good pressure. The old one was leaking through the body crimp and obviously not doing much.
StescoG66
Post by StescoG66 »
Does your car have the Jaeger or Veglia Borletti instruments?
Alfastrut
Post by Alfastrut »
StescoG66 wrote:Does your car have the Jaeger or Veglia Borletti instruments?
It's got jaeger instruments
StescoG66
Post by StescoG66 »
Excellent. Same as mine then. will purchase one. Thanks for the tip off :-)
dave.armstrong
Mine's got Jaeger
dave.armstrong
Alfastrut wrote:Purchased and fitted. Never had the Guage read such good pressure. The old one was leaking through the body crimp and obviously not doing much.
Mine is very responsive too.
StescoG66
Post by StescoG66 »
Well installed last night and quite a difference. thanks for the tip off chaps.
Also - and the purists will e horrified a this - but had to devise an alternative method of putting in a crankcase breather outlet as it was missing on my car. In short, managed to drill a 10mm hole in to the oil filler neck - stuffed with cloth to make sure no swarf went down there. Screwed in a compressor tool connection and sealed in place with quick steel. Seems to work OK :-)
Bodgy McBodgyface
Bodgy McBodgyface
StescoG66
Post by StescoG66 »
A bit of a thread resurrection. While rebuilding my engine I managed to snap the connecting lugs off my replacement unit. Does anybody know the OEM part number (and spec if possible) for the boxer pressure transmitter so I can cross reference to try to find another replacement. The one mentioned in the thread - Kerr Nelson SOP 141 - seems to be NLA. I presume a number of different manufacturers used the same spec unit.
Thanks again
Gary Orchard
Post by Gary Orchard »
Alfa original Part number is 60537246 or 545041
Not sure about the spec.
