1984 Gold Cloverleaf Sud Resto
Mufasa
Re: 1984 Gold Cloverleaf Sud Resto
Post by Mufasa »
justsuds wrote:yes, I have the badge as well as the rubber, both in good nic !
John I’ll be in touch Tuesday
Rory
05Alfa1662.0GrigioGeo-Daily
00Alfa1662.5Sporto-Verde Argo
Mufasa
Post by Mufasa »
Finally found the Green Cloverleaf alloy bolts!
Looks great 8-)
What a cracker!!
Looks lovely, nice one.
Mufasa
Post by Mufasa »
Was a very happy bunny yesterday when I bled the clutch and got it to work.
It was a one man job which is not ideal but I (over) filled the reservoir, opened the bleed valve,
I used one of those bleed tube/canister jobs. Used my jack handle to keep the clutch pedal
pressed down, closed bleed valve. Started car tried to get gear got grinding.....
Switched off, started it in first (clutch pressed fully down of course) and hey presto it worked!
Drove it around the yard where it's kept, engaging gears fine.
Then I had to take off both driver's side wheels as they weren't holding pressure.
Went to tyre bay and they resealed them.
Also found the spare wheel securing doo dah, the battery holding bracket and refitted the air intake
duct that goes on top of the bulk head. (As well as getting some 156 and 166 work done).
Wow busy Sunday . Top work chap . Another Alfa back on the road soon 8-)
Mufasa
Post by Mufasa »
Gone to mechanic for new timing belts, tensioners, water pump, 4 brake lines, braided hoses and some general tidying up...
Mufasa
Post by Mufasa »
Quick update.
It's passed its NCT (Irish MOT equivalent).
I've to pick it up on Saturday - can't wait!!!
Mufasa
Post by Mufasa »
It's back on the road:
https://youtu.be/eOBJZgKodPg
dave.armstrong
Post by dave.armstrong »
Sounds and looks great :D
Mufasa
Post by Mufasa »
dave.armstrong wrote:Sounds and looks great :D
Thanks Dave!!!
Sounds very sweet indeed 8-)
Mufasa
Post by Mufasa »
KevJTD wrote:Sounds very sweet indeed 8-)
Thanks Kev, can't beat a stainless steel exhaust!!!
Mufasa
Post by Mufasa »
Did a bit with the Sud last night.
Put GTV front seats in and rears from Alfa 33 Imola.
The fronts only have 2 bolts in (diagonally) and the rear top bit has a drill bit holding the split together
with tie wraps holding it to the receiver (complete cowboy job I know).
They fit well. 8-)
Mufasa
Post by Mufasa »
Thanks for the Plasbak recommendation (can't remember which of you guys posted it).
I went for the dark grey which TBH isn't that dark but has tidied up what I've sprayed so far very well IMO.
I have more photos if anyone is really interested in seeing more.
I used almost 2 rattle cans for both bumpers, one of the vents by the back door (tips for actual removal very appreciated-want to take the PS one off to paint)
and the air intake 'scoop' from the bonnet)
Nice job . They look a lot better any chance if a pic of the can and more details of the product . Can’t say I’ve heard of Plasbak.
Cheers.
Mufasa
Post by Mufasa »
My pleasure Louise
Mufasa
Post by Mufasa »
I ordered from my local motor factors in Dublin €9 per rattle can.
I've used 2 so far and will buy one more
https://www.conceptchemicals.com/products/plasbak-black
That has freshened up the plastic parts really nice.
She looks really nice and sharp.
Perfect.
Mufasa
Post by Mufasa »
Thanks Keg. I can't remember who on here recommended it but I'm very happy with the finish
They do look great 8-)
Mufasa
Post by Mufasa »
KevJTD wrote:They do look great 8-)
Thanks Kev.
I need to figure out whether I spray the door strips in situ or remove first.
And the trim behind the PS rear door.
I did the driver's side as it's slightly broken and I could lift it to get the newspaper in there
I think the door strips have a hard time laying flat again once removed.
If you spray them on the car then get some fine line masking tape rather than using regular masking to go right up to the edge, it doesn't bleed paint under it like regular stuff does ;)
Mufasa
Post by Mufasa »
Thanks Kev!
Mufasa
Post by Mufasa »
Got the door mirrors done too. 150 mile round trip to a classic car show yesterday
Mufasa
Post by Mufasa »
Quick update, passed our MOT equivalent until August 2021.
I finally got my mechanic to fix the front seats (he welded plates on the bottom and used the original bolts and anchor points).
He also changed the front PS wheel bearing, both track rod ends, fettled and tuned the carbs-it's idling at about 900 odd revs now
Pics of seat bottoms (916 GTV seats)
Nice job.
Enjoy. :D
Mufasa
Post by Mufasa »
Kegsti66 wrote:Nice job.
Enjoy. :D
Thanks-even the mechanic was gushing about the 'interesting' sound of the engine....
How old is your mechanic 19. :lol:
