Page 4 of 5
Re: My 84 Sud Ti Project
Posted: Fri Sep 18, 2020 3:10 pm
New door offered up for the first time . Not too shabby it’s got a couple of small storage dings and it needs a little bit of tweaking to get the fit spot on but nothing that can’t be dealt with at the bodywork stage.
Main thing is NO rust !!!
Re: My 84 Sud Ti Resto
Posted: Fri Sep 18, 2020 3:12 pm
Btw The front wing Is loose. That’s why the panel gap is so far out. The Next bus due through that gap is the 16.35 to Stoke
Posted: Thu Sep 24, 2020 2:19 pm
by Mufasa
Great stuff Loo!
Posted: Thu Nov 05, 2020 5:24 pm
Carbs rebuilt (40mm Weber’s)
Under bonnet decal kit
Posted: Thu Nov 05, 2020 5:28 pm
Where Do you keep your Sud ??
Mines in the attic !
Posted: Fri Nov 06, 2020 7:56 pm
Nice tidy attic Lou.
I need to board out my new loft and sort stuff that is currently in it balancing on the joists
Posted: Fri Nov 06, 2020 8:22 pm
Thanks Keith it’s not as tidy as it looks I’d like to board more of it tbh. There’s half a midget up there aswell.
Posted: Tue Nov 10, 2020 1:56 pm
by Mufasa
Nice work on your carbs!
Posted: Tue Nov 10, 2020 6:01 pm
Thanks Muf. I’ve gone with 40s as they Should compliment the Fast road cams and BV heads I’ve got in mind. The bottom end is almost finished I’ll post a photo when the engines done .
Posted: Thu Nov 12, 2020 3:23 pm
by Mufasa
LooLooSud33Spider wrote: ↑Tue Nov 10, 2020 6:01 pm
Ball park what do you expect it to put out BHP wise?
Posted: Mon Feb 22, 2021 3:04 pm
Apart from a few small details the bottom end is now back together and ready for heads . Which I’ve yet to do
Also got a big prezzie coming that will help with progress in the bodywork
Details to follow
Posted: Fri Feb 26, 2021 11:49 am
New (home made) inner wing splash flaps. As per original design
Little By little we’re getting there .
Posted: Fri Feb 26, 2021 7:24 pm
by rsfruitbat
Hi Lol
Splash guards look good. Did you use mudflap material? Which side should they go? wheel side or engine side of car flitch?
Posted: Fri Feb 26, 2021 8:46 pm
Hi Ade. They fit on the engine side of the inner wing. The material is just some 1.5mm rubber sheet off eBay. It appears to be tough enough but I guess time will tell and yes the originals were only stapled together !
I used my old grotty ones as a pattern. I’ve got 1.4m of the sheet so If you need some I can knock you a pair up I think they were the same on sprints
Posted: Sat Feb 27, 2021 6:01 pm
by rsfruitbat
Thanks for the offer Loo
Will let you know.
Posted: Sat Feb 27, 2021 9:10 pm
LooLooSud33Spider wrote: ↑Fri Feb 26, 2021 11:49 am
Spot on !!
They look the part.
Engine block looks nice as well .
Posted: Sat Feb 27, 2021 9:14 pm
Thanks Keith.
Posted: Wed Mar 03, 2021 7:34 pm
Started installing the shell on to the Rottiserie today’s. Has anyone else used one and did you have any problems with your chosen mounting points . At the front I’ve made some beefy brackets that pick up on the crossmember points so that should be ok it’s the rear that I’m wary of.
Posted: Fri Mar 05, 2021 3:43 pm
Well it’s on ! Seems to be well enough balanced when I rotate it and its all noice n toight .
Posted: Fri Mar 05, 2021 8:46 pm
Looks great Lou
Posted: Fri Mar 05, 2021 8:51 pm
by rsfruitbat
You beat me to it Kev
Posted: Fri Mar 05, 2021 9:09 pm
Thanks Chaps. I have to say this was made in the UK he’s only in Telford. By a guy called Ade Foreman at AF light engineering. I turned it through 90deg this afternoon and wow it’s going to make the repairs to the underside so much easier and therefore better. I’ve now got to decide how far I go with the underside do I
A) make repairs where needed and then try to match the original under seal just where needed
B) remove all old underseal make repairs reseam seal and then spray with paintable underbody protection and have the underside painted body colour
Thoughts welcome
Posted: Fri Mar 05, 2021 9:25 pm
A/ Sensible
B/ Too tempting.
As you say Lou, it makes the repairs so easy it's hard to resist getting carried away...
So B
Posted: Fri Mar 05, 2021 9:31 pm
I’m tend to agree Kev. As I’m trying to do the best job I can .The only problem is that sometime you can end up with a car that’s so nice you never end up driving it because you don’t want it to get dirty or splashed . It’s daft I know but where we live we’re surrounded by small country lanes so there’s always muck and shoite about from the local farms. I will be fitting arch liners to the front to help keep it from getting to bad. So I guess it’s B
Posted: Fri Mar 05, 2021 9:35 pm
Yes, agree you can fall into the trap of making it look too good to spoil. Been there, done that...
But consider it another way. Make it nice, all fresh, sealed and painted so it looks nice.
Then still blast along the lanes safe in the knowledge that you can safely hose it down underneath as there's no dodgy areas
Posted: Fri Mar 05, 2021 9:42 pm
I think that’s a sensible approach Kev . Btw what undercoating would you recommend? I guess it needs to be a soft drying and paintable ?
Posted: Fri Mar 05, 2021 10:13 pm
Lou,
have you moved to Oirland?
Posted: Fri Mar 05, 2021 10:23 pm
Oh no Dave that I haven’t Begorra.
Posted: Fri Mar 05, 2021 10:55 pm
Etch primer, seam sealer, stoneguard then topcoat over that.
Posted: Fri Mar 05, 2021 11:06 pm
Thanks Kev
