Sud front wing
Posted: Thu Dec 14, 2023 6:25 pm
Wanted.
Genuine S3 sud front wing (not pattern). SH ok as long as its rust free
Re: Sud front wing
Posted: Fri Dec 15, 2023 9:50 am
Lou,
If its a RH one you want, have a trip to Southport!
Ebay 115914878279
Re: Sud front wing
Posted: Fri Dec 15, 2023 9:54 am
...........he also has a LH one!
Re: Sud front wing
Posted: Sun Dec 17, 2023 5:00 pm
by junior
The chap i sold my spare one may still have it but he will have cut a small peice off the bottom by the door if I recall correctly.
Would you like me to check ?
Re: Sud front wing
Posted: Sun Dec 17, 2023 5:18 pm
Hi Junior. Is it a new or SH. I’m just after a genuine Alfa wing preferably rust free I’ve got a few spare new wings but they’re pattern and I’d rather fit a genuine panel if I can find one.
Many thanks
Re: Sud front wing
Posted: Sun Dec 17, 2023 8:24 pm
by junior
Hi. If i recall correctly and its been few years now, its a genuine Alfa one with only a bit of surface rust on the edges where its stood or been scraped as its been moved around. The chap i sold it to used it more as a pattern than to help him make sections to weld in to his car. He like you wanted to have as much genuine car as he could.
Re: Sud front wing
Posted: Sun Dec 17, 2023 8:26 pm
by junior
Oh and you might be able to answer a question I have. Do you know if the oil cap on the rocker box on such as a Alfa gt junior would fit on a Lancia Beta/Monte engine as the one on my car is lousy and leaks oil all the while.
It appears to be a regular problem.
Re: Sud front wing
Posted: Sun Dec 17, 2023 8:33 pm
Hi Junior. I’m pretty sure the Twin cam oil cap won’t fit your beta. The Nord cap just has two little external tangs that engage and run around the outside of the casting on the rocker cover. Whereas the Beta cap has a steel finger arrangement that engages and runs around the inside of the cam cover hole. Hope this helps. Lou
Re: Sud front wing
Posted: Tue Dec 19, 2023 6:49 pm
by junior
Of course. They are the wrong way round. Amazing how clearly you can see it after your reminded but cannot visually get it before. Thank you.
