Sud rear suspension bolts
Has anyone found a source of new bolts for the rear suspension. Looks like I’m going to have take the grinder to mine To remove the back end.
Re: Sud rear suspension bolts
The ones that go through the trailing arm bush?
Yeah but could do with a full set of for all rear arms .
Hello Lou,
I’ve used Namrick previously as the nuts and bolts are oem in appearance and easy to select and use from their online catalogue
https://www.namrick.co.uk/acatalog/Home ... s__28.html
Adam
Adam
Thanks for the link Adam. They look like a great source original spec bolts
I’ll email them and if needs be I could even send them samples.
