1.7 flat four crankshafts, we have available a number of standard crankshafts and ex race cross drilled cranks - all used. £70 each.
1.2 flat four crankshaft new unused [ 59 mm stroke ]. Open to offers.
1.7 8v heads - One pair of chambered, hydraulic tappet, cylinder heads complete with inlet manifolds. Heads decoked, valves lapped in and assembled with new valve stem oil seals. £200.00
All parts are in Lincoln - no problem if anyone wants to come and take a look at the 1.7 cranks to pick the one they want!
1.7 and 1.2 Cranks + 1.7 heads
Re: 1.7 and 1.2 Cranks + 1.7 heads
Hi Bryan, Dave Ashford is looking for a 1200cc crank, he’s on 07710 879526
I think he wants a 64mm stroke crank, but worth speaking to him anyway.
Thanks both - I did reply several weeks ago with a thanks to your tip off Tim but the message seems not to be here.
Dad spoke to Dave and he does indeed want a 64mm stroke crank. I've since put the 1200 crank and heads on the dreaded Ebay - I'm sure they will go in time!
