compbrake top strut mounts
Posted: Wed May 06, 2020 7:25 am
by rsfruitbat
Hi
has anyone used these?
does anyone recommend anything else?
Thanks rsfruitbat
Re: compbrake top strut mounts
Posted: Wed May 06, 2020 11:10 am
Hi Ade.
They look similar to the mounts in our car. Never had any problem with them
I think ours were made by TransautoSport many years go I hade to design and make adaptor plate to suit the later shell when re rebuilt the car as it had the Later 6 bolt mounts.
I’ve got some close up photos somewhere I’ll dig them out for you.
- 79160935-AED1-44A6-9E8B-55E06FF658D3.jpeg (32.25 KiB) Viewed 6729 times
Posted: Thu May 07, 2020 9:12 pm
by rsfruitbat
Thanks Lou
Posted: Tue Nov 24, 2020 3:15 pm
by Mufasa
I've a road going 1984 Sud Gold Cloverleaf that is lowered and has too much negative camber up front.
Any reasonably priced solution for top mounts?
Or has anyone created adjustable camber at the bottom of the strut?
Posted: Wed Nov 25, 2020 10:57 pm
The hub bolt holes can be elongated to allow the angle between hub and strut to be altered enough to correct camber, that's how I did mine on advice from people in the know
I'll try and dig some shots out.
Posted: Thu Nov 26, 2020 6:19 pm
by Sud 145
That's what I had on the struts I got from John, Paul at MDZ Italtec spent some time setting them up for me because my Sud is lowered.
Posted: Wed Dec 02, 2020 1:57 pm
by Mufasa
KevJTD wrote: ↑Wed Nov 25, 2020 10:57 pm
Thanks Kev, very well known and liked specialist here in the ROI did recommend that.
by Mufasa
Sud 145 wrote: ↑Thu Nov 26, 2020 6:19 pm
That's what I had on the struts I got from John, Paul at MDZ Italtec spent some time setting them up for me because my Sud is lowered.001.JPG
Tony G is that you?
Posted: Wed Dec 02, 2020 6:18 pm
by Sud 145
Mufasa wrote: ↑Wed Dec 02, 2020 1:57 pm
Tony G is that you?
Yes 'tis I matey.
Posted: Wed Dec 02, 2020 6:47 pm
by Harry_p
I wonder if something like this could be adapted to fit?
https://www.ebay.co.uk/itm/153043676285
Even if you could get one stud through to hold it in place and mark and drill the mount for the rest. Personally I’d rather drill / modify the mount than the car body.
Might have to have a measure up because I don’t think I’m going to be able to leave my ride height alone for much longer...
